DrumidyCover.zipSTL files for the cover box. now it is all here.x-zip-compressed - 876.03 kB - 04/04/2021 at 15:56 |
MainBoard_Gerber.zipGerber files of the main board. Initial version.x-zip-compressed - 59.67 kB - 04/04/2021 at 10:23 |
SensorSide_Gerber.zipGerber files of the small boards installed on the drums.The board's design is too "universal" and should be "optimized". But it works nevertheless. x-zip-compressed - 10.32 kB - 04/04/2021 at 10:23 |
Drumidy_V0.2.binFixed config routine. the firmware tested for few months alreadyoctet-stream - 64.63 kB - 04/04/2021 at 10:20 |
Drumidy_v01.binFirst version of firmware.it uses all pin of STM32G432KB board as inputs (both analog and digital) Pins PA11 and PA12 configured as USB midi output. octet-stream - 64.52 kB - 02/27/2021 at 16:43 |
