0_small.jpgnew back panel viewJPEG Image - 414.15 kB - 01/21/2021 at 14:19 |
1_small.jpgwith protective blind plugJPEG Image - 379.38 kB - 01/21/2021 at 14:19 |
2_small.jpginside viewJPEG Image - 530.78 kB - 01/21/2021 at 14:19 |
3_small.jpgXT60E-M barely fitsJPEG Image - 555.05 kB - 01/21/2021 at 14:19 |
4_small.jpgpanel cutout + modified XT60E-MJPEG Image - 848.16 kB - 01/21/2021 at 14:19 |
5_small.jpgwires soldered to screw tab, than screwed to the binding post for easy assemblyJPEG Image - 717.36 kB - 01/21/2021 at 14:19 |
6_small.jpgbend wires around to solder lugs and solder from the outsideJPEG Image - 818.02 kB - 01/21/2021 at 14:19 |
7_small.jpgstackup. note that the pcb is only touched by bare metal parts.JPEG Image - 323.19 kB - 01/21/2021 at 14:19 |
8_small.jpgNew fan with replaced feedback resistorsJPEG Image - 744.25 kB - 01/21/2021 at 14:19 |
9_small.jpgblind XT60H-F plug; solder connections covered with hotglue to prevent shortsJPEG Image - 225.00 kB - 01/21/2021 at 14:19 |
