* * USING A uTERM2-S TERMINAL * *
A project log for 68k-MBC: a 3 ICs 68008 homebrew computer
An easy to build homebrew SBC with a 68008 CPU. Two HW options: Lite and Full. Lite allows to build a 3 ICs 68008 system running CP/M-68K.
just4funJust4Fun 09/10/2021 at 15:300 Comments
I've just relesed the uTerm2-S, a new multi-emulation color RS232 terminal for the 68k-MBC (but not only...). It is based on a ESP32 cheap module and is designed to use the FabGL library.
More info on the uTerm2-S can be found here.
The following image shows the uTerm2-S (previous PCB revision) connected to a 68k-MBC using the custom RS232 cable (A020221) previously described:
Here I've set the screen of the uTerm2-S to 132 columns x 75 rows to have a large display area:
In the following images a 68k-MBC powered with a uCom add-on board and connected to a uTerm2-S terminal (here the terminal was set to 128 columns x 40 rows):
