gPEAC_1M.tbzSieve generator, sieve, and scanner for the gPEAC orbits, "1 million" edition.x-bzip-compressed-tar - 81.95 kB - 05/17/2023 at 14:51 |
gPEAC_scans_1M.tbzAll the logs of the scan up to 1000615, and updated scripts. Raw data for those playing at home and wanting to reproduce everything (or in case of mistake)x-bzip-compressed-tar - 2.37 MB - 05/17/2023 at 12:43 |
gPEAC_500K.tbzSieve generator with the 501K range (47038 known orbits), sieve program, orbit scanner with fancy xterm launcher...x-bzip-compressed-tar - 283.89 kB - 05/09/2023 at 02:11 |
gPEAC_scan_logs_501K.tbzall the maximal and perfect orbits of gPEAC, from 2 to 501000. .h file included. duplicate 89651 fixed.x-bzip-compressed-tar - 1.13 MB - 05/09/2023 at 01:20 |
gPEAC_scan.tgzThe new faster scanner ! see log 150.x-compressed-tar - 51.74 kB - 05/06/2023 at 07:54 |
sieve_booster.tgzmuch better version than sieve.tgzx-compressed-tar - 49.13 kB - 05/06/2023 at 06:00 |
sieve.tgzchecks if a 64-bit number is a bad candidate (command-line program)x-compressed-tar - 1.96 kB - 05/06/2023 at 00:35 |
create_sieve.tgzA C program to generate a sieve from the gPEAC.2-131540.txt logx-compressed-tar - 37.14 kB - 05/05/2023 at 23:21 |
gPEAC_optimsation.tgzA collection of increasingly optimised gPEAC scan routines, as well as the proofing and benchmarking codes and scripts. See log 144. "More results !"x-compressed-tar - 10.19 kB - 05/04/2023 at 00:01 |
bench.diff_float.cdifferential benchmarking stub. orbits.c not provided yet.x-csrc - 2.95 kB - 05/01/2023 at 19:46 |
bench.basic.cuses RDTSC to evaluate the jitter of POSIX SIGALRM/setitimerx-csrc - 1.52 kB - 04/30/2023 at 10:47 |
gPEAC.2-131540.txt.gzList of maximal and perfect orbits, from 2 to 131540.gzip - 101.30 kB - 04/05/2022 at 02:03 |
moduli_02.clike moduli_01.c but can handle larger data, for m>65Kx-csrc - 1.17 kB - 01/29/2022 at 21:36 |
mods.log1880 first results with maximal or double-maximal orbit lengthsx-log - 40.00 kB - 01/29/2022 at 20:36 |
moduli_01.ccheck orbit length for non-power-of-two modulix-csrc - 1.14 kB - 01/29/2022 at 20:36 |
fusion_20220109.tgzcontains dump7ck, pscan_10 and fusion, good enough to test up to w26.x-compressed-tar - 7.13 kB - 01/09/2022 at 13:34 |
log.22.p7k.bz2p7k log of w22 compressed with bzip2.x-bzip - 37.18 MB - 01/08/2022 at 00:30 |
logs_p7k_03-21.tbzp7k logs of w3 to w21 (compressed with bzip2).x-bzip-compressed-tar - 34.55 MB - 01/08/2022 at 00:27 |
dump7ck.tgzdump a binary p7k file into a human-readable ASCII stream to stdoutapplication/x-compressed-tar - 2.06 kB - 01/03/2022 at 09:30 |
pscan_20211229.tgzenhanced version of the threaded scannerx-compressed-tar - 5.09 kB - 12/29/2021 at 08:39 |
pscan_20211224.tgzpthread-enabled version for parallel-scanning. outputs p7k-formatted logs.x-compressed-tar - 4.35 kB - 12/24/2021 at 12:34 |
parscan01.tgzNew scanner with distributed ranges, p7k packing format and a couple of scriptsx-compressed-tar - 3.04 kB - 12/14/2021 at 05:06 |
scan_1x_02.cA basic single-threaded scanner for the smaller widths.x-csrc - 2.53 kB - 12/04/2021 at 23:17 |
faster_05.cA reference code for the scan algorithm: unrolled 2× and handles semi-arcs. Condition bug is solved.x-csrc - 1.77 kB - 12/03/2021 at 21:57 |
p4ck.cpacks 2 decimal digits in one bytex-csrc - 1.37 kB - 12/03/2021 at 18:15 |
kc4p.cunpacks a byte into two decimal digitsx-csrc - 1.04 kB - 12/03/2021 at 18:15 |
snippets_v3.cbasic PRNG, checksum, scrambler/descrambler (sans and avec carry) using PEACw16 in Cx-csrc - 4.39 kB - 10/10/2021 at 14:28 |
sous-titres.txtsubtitles for the French version of the video about trthe PEAC generatorplain - 14.63 kB - 10/06/2021 at 09:30 |
zoumout2.tgzfiles to compute and render the 16 zoom-out videosx-compressed-tar - 2.82 kB - 09/14/2021 at 04:19 |
Marsiglia _ add with carry RNG 1177005878.pdfSome great theory from 1991Adobe Portable Document Format - 1.76 MB - 09/14/2021 at 04:17 |
html_slides.tgzfiles for log73.x-compressed-tar - 1.27 kB - 09/06/2021 at 01:18 |
zoumout.tgzall the files (except the music) necessary to rebuild the zoom-out video.x-compressed-tar - 2.91 kB - 08/16/2021 at 10:49 |
bidir_orbit_01.cFinally a bidirectional scanner that works.x-csrc - 5.96 kB - 08/15/2021 at 08:49 |
Pisano16x2_v5.cInterim version. Some promising features appear but the code for the unrolled function is not "good".x-csrc - 5.28 kB - 08/09/2021 at 01:11 |
PEAC4x2.cjsCircuitjs file for a 4-tap LFSR-like structure.cjs - 6.83 kB - 08/08/2021 at 00:10 |
test_Pisano16x2_v3.cmore features to check mixing and collisions.x-csrc - 1.64 kB - 08/06/2021 at 08:04 |
Pisano16x2_v3.cAdditive versionx-csrc - 2.02 kB - 08/06/2021 at 08:03 |
case_against_xor.tgzsome files that compare XOR and ADD for mixing.x-compressed-tar - 1.97 kB - 08/06/2021 at 07:11 |
1dcasim_a.html.txtSim as below, with broadcast command feature.plain - 11.65 kB - 08/04/2021 at 03:11 |
1dcasim_9.html.txtSim of the chain protocol, with a working and more accurate addressing system.plain - 10.64 kB - 07/27/2021 at 05:45 |
1dcasim_7.html.txtsimulation of the queue insertion system for the FPGA interco. Rename the file, remove.txtplain - 7.40 kB - 07/25/2021 at 02:53 |
1dcasim_5.html.txta dynamic HTML simulator for the interco chain in FPGA. preliminary and incomplete.plain - 5.28 kB - 07/24/2021 at 23:50 |
dispatch_02.cenabling computation of arcs in w32x-csrc - 2.42 kB - 07/18/2021 at 02:15 |
PEAC_core.tgzFirst test of a VHDL versionx-compressed-tar - 1.54 kB - 07/13/2021 at 02:41 |
job_logs.tgzlog files for w3 up to w20x-compressed-tar - 18.09 MB - 07/09/2021 at 23:49 |
gold_01.cFirst working scanner to explore the behaviour of the "jobs" (serial version)text/x-csrc - 1.47 kB - 07/09/2021 at 22:14 |
test_w26.cCompare the original (bit-limited) algo with the new (non-masking) algo.x-csrc - 1.29 kB - 06/18/2021 at 00:42 |
Pisano16x2_v2.cFaster checksumming routine, with 16 and 32 bits versions.x-csrc - 1.30 kB - 05/25/2021 at 11:42 |
pt_orbit_07.cruns both forward and backwards iterations in parallel, sometimes they meet in the middle.x-csrc - 8.32 kB - 05/25/2021 at 04:10 |
orbits_forwd2.cMicrobenchmark that compares the running time of forward and backwards computation.x-csrc - 1.78 kB - 05/13/2021 at 03:21 |
orbit_resume.csame as orbit_count.c but with command line options to resume the search at a given point.x-csrc - 1.99 kB - 05/07/2021 at 06:03 |
Pisano16x2.cA simple function that computes the checksum of a buffer.x-csrc - 815.00 bytes - 04/29/2021 at 01:21 |
test_Pisano16x2.ca dumb main() to verify that Pisano16x2.c works.x-csrc - 469.00 bytes - 04/29/2021 at 01:21 |
orbit_count.cMeasures the first orbit of the Pisano-Carry state space (the long way)x-csrc - 1.28 kB - 04/27/2021 at 05:08 |
orbits_anim.cGenerates one image for each step of computation. (updated version)text/x-csrc - 4.92 kB - 04/26/2021 at 12:33 |
orbits_bmp.cmaps the full state space of the algorithms for arbitrary bit widths and export this map to .bmp filesx-csrc - 4.81 kB - 04/26/2021 at 01:55 |
orbits.cmaps the full state space of the algorithms for arbitrary bit widths.x-csrc - 3.09 kB - 04/25/2021 at 04:28 |
prng.cA toy PRNG that outputs 16 bit per cycle, with 65 bits of entropy.x-csrc - 1.19 kB - 04/21/2021 at 03:38 |
orbits_fs16c2.cmaps ALL 8G states and proves the structure of the orbits.Requires > 8GB RAM and 1/4h running time... x-csrc - 5.63 kB - 04/19/2021 at 18:39 |
Orbits_FS16C2_v2.html.txtMore accurate version that takes the carry into account for the intersections.Still not valid, see the C code! plain - 3.05 kB - 04/19/2021 at 01:15 |
Orbits_FS16C2.html.txtEnumerate all the 10 orbits that go through X=1Gives inaccurate results. plain - 2.96 kB - 04/18/2021 at 02:04 |
Orbits_FS16x2.html.txtFibonacci checksum test : Checks if 2 states X,Y,C belong to the same orbit of the 16×2 configuration with carries.plain - 1.99 kB - 04/18/2021 at 00:01 |
plain - 1.73 kB - 04/16/2021 at 04:26 |
test_wrap64K.carry.html.txtcheck that the sequence runs for 2G cycles (takes "several seconds" to compute...) for a 2×16 bits system with carry.plain - 1.24 kB - 04/14/2021 at 04:08 |
test_wrap64K.html.txtPisano mod 65536plain - 1.14 kB - 04/14/2021 at 02:54 |
test_wrap256.html.txtPisano mod 256plain - 996.00 bytes - 04/14/2021 at 02:54 |
