HYX_files.tgzThe complete files for C, VHDL and some JSON.x-compressed-tar - 7.05 kB - 11/12/2021 at 07:13 |
hyx_filters.vhdlVHDL filter (output only so far)x-vhdl - 2.58 kB - 11/12/2021 at 06:17 |
hyx_tb.vhdltest file for hyx_filters.vhdlx-vhdl - 682.00 bytes - 11/12/2021 at 06:17 |
example.hyxA self-documenting file format example.hyx - 954.00 bytes - 11/06/2016 at 13:12 |
example.ref.binThe expected raw binary file generated from example.hyxoctet-stream - 19.00 bytes - 11/06/2016 at 13:12 |
input_hyx.c#include-able parser in C (needs external callbacks for in and out)x-chdr - 4.23 kB - 11/06/2016 at 13:14 |
hyx2bin.cexample file that uses the above parser to translate a .hyx file to a raw binary file.x-chdr - 2.30 kB - 11/06/2016 at 13:14 |
output_bin-hyx-json.can output "filter" that generates bytes in raw binary, .JSON or .HYX formats.x-chdr - 3.21 kB - 11/06/2016 at 13:14 |
plop.hyxExample / Test data sethyx - 769.00 bytes - 11/06/2016 at 13:12 |
plop.jsonExample / Test data setJavaScript Object Notation (JSON) - 809.00 bytes - 11/06/2016 at 13:12 |
plop.binExample / Test data setoctet-stream - 220.00 bytes - 11/06/2016 at 13:12 |
