Schematic z80 1-Bit ALU cell but it's op amps._2021-11-03.pdfhere's a bunch of actual schematics that I drew up to explain the components of my final build.Adobe Portable Document Format - 237.37 kB - 11/09/2021 at 15:46 |
Z80 1-Bit ALU cell (based on ken shirrif's blog - unmodified).circHere's the reverse engineered 1-bit ALU calcuation Cell design taken from Kens blog.circ - 9.93 kB - 11/09/2021 at 18:24 |
Z80 1-Bit ALU cell (based on ken shirrif's blog - modified).circhere is a logic diagram of the final project ALUcirc - 9.96 kB - 11/09/2021 at 15:44 |
1 BIT ALU WITH DECODE LOGIC.circHere's a logism mock up of the ALU and its decode -- I ended up not going with this as it became clear I was going a different direction with the project. Instead i switched to the same configuration used by the Z80.circ - 18.88 kB - 10/19/2021 at 18:24 |
