Connections_RTC_BRAM.odtConnections list for RTC / BRAM card.text - 14.88 kB - 06/14/2017 at 04:20 |
MKHBC-8-R2-CPU.schSchematic diagram of the computer's circuits (Express SCH).sch - 298.13 kB - 06/12/2017 at 01:36 |
ListOfParts_RTC_BRAM.odtList of parts for the RTC/BRAM PCB.text - 15.66 kB - 05/31/2017 at 06:36 |
MKHBC-8-R2-Netlist.odtNetwork (connections) list of the computer circuits.text - 19.05 kB - 05/31/2017 at 06:36 |
mkhbc.cfgConfiguration file for linker (cl65).cfg - 263.00 bytes - 11/19/2016 at 16:48 |
mkhbcos.asmUART, 6502 Monitor routines (ca65).plain - 40.32 kB - 11/19/2016 at 16:47 |
MKHBC-8-R1-EPROM.jpgEPROM circuit diagram.JPEG Image - 309.71 kB - 11/19/2016 at 16:46 |
MKHBC-8-R1-BaseRAM.jpgBase 32 kB of RAM circuit diagram.JPEG Image - 247.41 kB - 11/19/2016 at 16:45 |
MKHBC-8-R2-BankedRAM.jpgRTC + Banked RAM circuit diagram.JPEG Image - 573.84 kB - 11/19/2016 at 16:44 |
MKHBC-8-R2-UART.jpgUART card circuit diagram.image/jpeg - 764.65 kB - 11/19/2016 at 16:44 |
MKHBC-8-R2-IO-bus.jpgI/O expansion bus circuit diagram.JPEG Image - 1.75 MB - 11/19/2016 at 16:42 |
MKHBC-8-R2-CPU-bus.jpgCPU bus circuit diagram.JPEG Image - 1.21 MB - 11/19/2016 at 16:41 |
MKHBC-8-R2-CPU-card.jpgPart of CPU card curcuit diagram: CPU, CPU clock, reset, signals, address decoding.JPEG Image - 1.27 MB - 11/19/2016 at 16:38 |
mkhbc-8-r2-rtc-bram.pcbExpressPCB - the PCB layout of RTC + Banked RAM board.pcb - 11.97 kB - 11/19/2016 at 16:35 |
mkhbc-8-r1-uart.pcbExpressPCB - the PCB layout of UART board.pcb - 42.40 kB - 11/19/2016 at 16:34 |
mkhbc-8-r2-cpu.pcbExpressPCB - the PCB layout of CPU card. Note that I build my boards using point-to-point soldering on prototype boards (I know, I am in the middle ages right now) so there are no traces designed at this point.pcb - 19.91 kB - 11/19/2016 at 16:30 |
MKHBC-8-R1-Design_and_Spec.odtDesign and Specifications document.text - 208.57 kB - 11/19/2016 at 16:29 |
