Repurposing an old nixie thermometer
Returning to gear neglected for 35 years
I've decided to finally have a go at the bulky thermometer with nixie displays that's been languishing in my cupboard. I bought it at the same surplus shop where my Beckman plasma clock came from.
New year, new hacks
I've decided to finally have a go at the bulky thermometer with nixie displays that's been languishing in my cupboard. I bought it at the same surplus shop where my #Restoring a Beckman neon display clock came from.
The box is quite sturdy and bulky and was obviously installed in a rack in a factory. A search on Ircon shows that the company was a manufacturer of measuring equipment established in Illinois. Now it seems to have been absorbed into Fluke. That makes sense, they are into measuring equipment.
The front has tinted glass behind which sit 6 nixies. There are a couple of adjustments accessible, but on the inside they had been disconnected, perhaps by me. The legend confirms that it was a thermometer as it used an iron-constantan thermocouple which can measure temperatures up to 750°C. I also remember that it displayed the voltage at the input terminals. So it was factory instrumentation.
Nothing turned up for the model number search. That's not surprising. It was probably a small run product and I doubt if any documentation is extant.
Opening it up showed that it has two large circuit boards. One holds the analog circuitry, and the other has lots of RTL chips and the nixies. Wow, even older digital chips than those I used in #DTL binary clock. The analog board also held an old school power supply transformer. The equipment is from the 70s as the date codes on the RTL chips attest, so no SMPS at that time.
There was third smaller board which appears to be the communications board leading to the DB25 connector at the back. But the biggest surprise was that I had already hacked it decades ago, and I had forgotten the extent of my hacks. I definitely had to jumper the power transformer differently for 230V AC power. There was an interloper UART board taken from the same LA30 printer that I used the character generator board for #Flashing LEDs from old printer electronics. Also some handwritten notes by me about how to instruct the thermometer to send the measurements through the serial interface. I don't remember getting it working; life got in the way; I graduated, moved away, got a job, etc. etc.
It came back to me. I had connected a biased silicon diode to the input terminals and viewed the forward voltage, around 0.6 to 0.7 V. I remember that I had ideas of sending this data to a CP/M computer I owned to convert this to a temperature. The idea was that I could measure the outside temperature with a remote probe before venturing outside. (I studied in a place with a cold climate and before Internet weather pages.) Well I certainly don't need another thermometer. Now for a few bucks one can buy a battery powered gadget smaller than a pack of cards that shows inside and outside temperature, humidity, as well as the time and date.
What interests me at this point are the nixies. I want to make a 6-digit display that will display the number sent through a WiFi MCU, e.g. an ESP8266 or ESP32. So I will have to decipher the circuitry.
At this point I will post updates in separate project logs, otherwise I will hit the length limit on the Details section and people will get tired of scrolling past what they have already read. I'll just provide links here to the logs:
  1. Diving into the circuit
  2. Identifying the components
  3. Decoding the decoders
  4. Driving the nixies with extra circuitry
  5. Interface design
  6. Preparing new circuitry
  7. Testing the addon boards
  8. Preparing the nixie board
  9. Light up!
  10. Closing the case
  11. Final touches
  • Reusing the idea
    Ken Yap12/14/2022 at 00:37 0 comments
    The circuit design for the nixie drive transistors in this ancient piece of equipment has been reused in my #Modularnixie project taking advantage of modern PCB manufacturing and assembly.
  • Final touches
    Ken Yap04/13/2022 at 06:29 0 comments
    The deficient digits did heal with use, especially the ten hour digit so I have no more excuse to sleep in after 1000. 🤣
    It's common to surround nixies with a complementary colour of light such as blue, Due to the socket and tube base, it's not possible to do this through the bottom. So I tried placing a couple of LEDs in the background. Unfortunately the back of the nixie is opaque to prevent the glow from lighting the back or sides so the photo is the best I could do. 🤷
  • Closing the case
    Ken Yap04/04/2022 at 07:10 0 comments
    After the board had been running smoke-free 😉 for a while I cranked up the HT to 200V and the nixies brightened up. One of the 5 nixies turned out to be dead (gas leaked out?) so I have no spare if any of the 4 fail. Perhaps I could plug the symbol nixie into the 10 hours position for a weird display, which is acceptable as my other clocks are weird too. 🤣
    In the photo you see a drawback of nixies, i.e. the digits are not in the same plane; the 5 is noticeably further back than the 1 in front. So nixies need to be viewed face on.
    Another thing I noticed was some digits were not fully-formed, part of the cathode wouldn't glow. Still readable though. I swapped the nixies around so that the deficient ones would be in less important positions. I put the nixie with a deficient 8 in the 10 minute position which will never show 6-9. I put the nixie with the deficient 0 in the 10 hours position. In this workaround I sleep in until after 10 so that I don't see the 0. 🤣
    A bit of searching for information about nixie wear found a post where it was suggested that nixies that have been out of action for a long time need to be "exercised" and the cathodes will heal. I hope that is the case. I won't try those remedies that suggest overdriving the nixie for a while. In my spare time I might research deeper out of curiosity. Anyway there is nothing I can do, short of paying too much for replacements. They work as well as I can expect. I just wish the case wasn't so big.
    Here you see the two extra boards added to the main board. On the left is the matchbox size 12V to 200V boost converter and the larger board is the #3 line to 32 line output expander. Hmm, I should clean it up a bit with isopropanol. The main board is now just a carrier for nixies, the rest of the circuitry on it is not connected, save through GND, and not powered. 12V from a standard SMPS adaptor powers the unit, and the MCU board is at the back of the case so that the set buttons are accessible.
    So that's it then, I can have my bench space back. Closing the case now. 🤣
  • Light up!
    Ken Yap04/01/2022 at 08:47 0 comments
    After the previous log, I wired up the outputs of the expander to the identified points on the base PCB with 28 hookup wires, plus 1 ground wire. Fortunately I had enough wire in many colours so I could colour code the lines.
    Next I connected the 200V anode line on the board to the 12V power supply. A couple of blue and white LEDs were plugged in with the cathode lead to the 0 and 1 cathode holes and the anode leads to the anode hole of the tube socket. With about 9V across the 20k resistor this gives about 0.45 mA current, enough to light the LEDs. The LEDs duly turned on when the minutes ended in 0 or 1, proving that the biquinary drive scheme was working properly.
    I left it like that for a week as I had other life matters demanding my attention, and also to allow any possible issues to emerge.
    Tonight, tired of procrastination and cowardice, I disconnected the 12V jumper then wired up the 12V to HT boost module and the HT out to the anode supply point. With no nixies plugged in, I measured the HT at about 170V. Must have been set at that by the factory. I cranked up the HT line with the trimpot to about 175V to ensure reliable firing. Later on I'll raise the HT to the rated 200V for full brighness.
    I plugged the nixies in and they just worked. Must have been decades since the gas inside was ionised. The minutes digit had a bug where it simultaneously showed both 4 and 6, or 5 and 7. This was simply the result of solder bridge between the 4/5 and 6/7 drive lines and readily fixed.
    The result is in the headline photo. I'm chuffed. 🤗 And no, it's not a joke, I know what day today is. Good start to the weekend.
  • Preparing the nixie board
    Ken Yap03/15/2022 at 05:44 0 comments
    As mentioned in the log Decoding the decoders, a biquinary scheme is used to drive the cathodes. Briefly, there are 10 HV switching transistors, but they are arranged in 2 banks of 5, with a low side transistor switch to select the odd or even bank. This means that 7 lines are used to select 1 of 10. You can see the 4 banks of 10 above the sockets, and the 4 pairs of bank selector transistors above them. These were driven from the flip-flops. I will be driving them from my #3 line to 32 line output expander board.
    I removed the flip-flops so there are no stray connections to the bases of the transistors. Even though the old RTL logic remaining on the board will not be powered, there might be stray paths to ground. Desoldering the flip-flop ICs wasn't as difficult as I feared. I needed only a normal conical tip soldering iron and a vacuum solder sucker. I didn't want to escalate to the heat gun because that can damage the board and components. In the end 10 out of the 12 ICs came out undamaged and I broke 2. After that I gave the area a good wipe with isopropanol.
    Notice that some of the pads were lost. Those didn't survive the heat. This double sided board doesn't have plated through holes, either the trace was on one side only, or the component lead passed the connection through. I think in that era PTHs were done using rivets. But since the pads I want are terminating connections, I only have to solder my wire on the side with the pad and trace. I identified the correct pads by tracing to the bases of the transistors, and labelled them, but I didn't have a fine tipped marker. No matter, I've documented the layout on paper. The layout is identical for all the other digits.
    If you have a sharp eye you'll notice some wire pads labelled 01 OE 45 and so forth. These are in fact the inverse outputs from the flip-flops (i.e. the ~Q outputs) intended to drive the comms board, no longer needed, so not relevant to my scheme, but helpful to confirm the correct pads.
  • Testing the addon boards
    Ken Yap03/06/2022 at 07:15 0 comments
    Least significant nixie digit drive shows Even and 2/3 lines active, thus the 2 cathode is to be on.
    Now that I have assembled the #3 line to 32 line output expander board, there is no more excuse for procrastination. So I connected it up to the #Quick and simple STM8 board with TCXO, rebuilt the software to drive the 74HC595 shift registers instead of a TM1637 and flashed the STM8 MCU. Since the DS3231 TCXO keeps time even in the absence of power, I know what to expect the display to show. I have connected LEDs only to the least significant digit (minutes) but from previous testing, the whole shift register chain should work.
    At the top left is the power adaptor board which regulates the input voltage from a 12V wall wart power supply via the barrel socket to 5V and 3.3V. Here it's used only to tap into the 12V as there is a 5V LD1117 regulator on board. The adaptor is a dollar or two ordered online. The board is plugged into a breadboard which here only provides connection points. It was previously used with the Arduino Uno for earlier testing.
    The third board, not shown, is an off-the-shelf 12V to 200V (adjustable) boost converter. All of the add-on boards to the thermometer will be powered by the 12V wall wart. The expected draw from the power supply is around 200-300 mA, well within the capability of the many spare wall warts in my spares hoard.
  • Preparing new circuitry
    Ken Yap02/22/2022 at 10:06 0 comments
    There have been no posts but I have been designing the replacement circuitry for this ancient box. The shift register PCB will be delivered soon. Originally I thought I would use an ESP8266 or ESP32 module to read data to display over WiFi. On further thought there isn't much you can send over the air to numeric nixies so it would be a waste of technology. Instead I will connect a STM8 based clock board using a DS3231 TCXO for accurate timekeeping, briefly described in #Quick and simple STM8 board with TCXO.
    So there will be three small boards to put into the case, the clock board, the shift register board, and an off the shelf 12V to 170V boost converter. The whole thing can be powered by a 12V wall wart.
    The picture above shows the clock board being tested with a TM1637 display.
  • Interface design
    Ken Yap01/08/2022 at 09:52 0 comments
    I already have an idea of what the shift register GPIO should look like. In a previous project #An uninnovative linear LED display I put the 74HC595 8-bit serial in parallel out shift register to work. This is a remarkably useful and cheap chip. It contains a latch so that the data shifted in can be held until the next update. It can be cascaded to any practical length. It can source or sink current. It's is very simple to drive, the software routine is easy to understand.
    4 digits means 28 lines are needed. The next multiple is 32 = 4 shift registers, so I can allocate a whole byte to each digit. The length of register chain is not a problem as it doesn't take long to shift in 32 bits, much shorter than the update period for the envisaged use as a display.
    While I only need one interface for this project, the horrors of perfboard assembly have put me off anything more complicated than a chip or two. 100x100 mm PCBs are so cheap, only a couple of bucks each delivered, so I will make a design that I can reuse for other projects. It will be a general purpose 32 line GPIO, or rather GPO, board.
    This project will go into hibernation until I have finished the SRGPO project.
  • Driving the nixies with extra circuitry
    Ken Yap01/06/2022 at 23:37 0 comments
    Although I have suggested that the counters may be arranged in a 1-2-2'-4 configuration rather than 1-2-4-8, this has not been verified by more circuit tracing. But I don't have to do this because I don't intend to use the counters anyway.
    So the question is where to interpose an extra circuit to drive the nixies from a WiFi MCU, as planned? Should it be before the latches, or after? After is easier, as the shift register GPIO will already come with a latch, and there is no need to power the MC778s to keep them working as latches. Instead of cutting traces, probably the easiest way to connect to the driver transistors is to desolder the MC778s from the board, using some combination of soldering iron, solder sucker, solder wick and heat gun. This also has the advantage that the pin holes exposed by the removal of the chips are concentrated in particular areas corresponding to the digits, so the flying leads to an auxiliary PCB will be neater.
    As mentioned the driver scheme uses 6 inputs to encode 0-9. The even/odd input is actually 2 lines, so 7 lines are required in all. We could invert the even input to get the odd input, but a shift register GPIO will have lines to spare so we can avoid an inverter.
    There is actually one more pass transistor below the even/odd transistors, which seems to be for display blanking. Easiest solution would be to simply bridge the C-E pins of that.
    I haven't discussed what to do with the symbol nixie and the 0/1 nixie. At this point, the easiest solution is to just unplug those nixies, to get a 4 digit display, one spare digit nixie, and one symbol nixie to ponder what to do with.
    Another goal was to substitute a more efficient power supply. Since the RTL chips don't have to be powered as the driver transistors only need base drive current, I no longer need the 3.6V logic supply. The 200V nixie supply can be replaced by a boost converter. Then I don't need to supply any power to the transformer and all the other circuits on the board won't draw current. The whole box and the WiFi MCU could be powered by a wall wart SMPS. That also solves the problem of the dangerous exposed mains terminals at the back. I could remove the RS232 socket to provide an entry hole for the interface cable.
    My ideas on the shift register interface and the power supply will be in the next log.
  • Decoding the decoders
    Ken Yap01/06/2022 at 10:18 0 comments
    Now I have to work out how the nixies, which are 1 of 10 indicators (ignoring the decimal point) are driven from binary inputs. So I examined the driver transistors and the display latches feeding them using optical trace scanning (my eyes 😉) and a continuity meter.
    Each nixie is driven by 10 transistors grouped 5x2. Each pair of 5 pairs has bases wired together. The reason will be evident in a moment. The circuit is pretty much similar to the following page I have excerpted from the RTL Cookbook I fetched. So instead of 4 binary inputs weighted 1-2-4-8 as we would expect nowadays, there are 6 inputs. The first is the even/odd line, and the others are the 0/1 2/3 4/5 6/7 and 8/9 inputs. So for example to display a 7, the odd input is active and the 6/7 transistors are driven but only one will conduct, the one whose emitter is grounded by the odd driver transistor.
    Tracing the inputs of the transistors from the MC778 chips reveals that two 2N5134 transistors switching between even and odd digits are driven in antiphase from one flip-flop using the Q and ~Q outputs. The 5 other flip-flops drive the 5 pairs of 2N4409 high voltage transistors. These 6 flip-flops contained in 3 MC778 chips, and there are 4 columns of 3, for the rightmost 4 digits. We'll ignore the leading 0/1 and the +/- nixies for now.
    How does one get from a BCD counter to this biquinary code? The RTL Cookbook provides one answer. The counter stage is not a 1-2-4-8 scheme, that requires too much decoding. Instead it is probably a 1-2-2'-4 scheme shown in the next diagram. By the use of a few extra gates this is converted to a biquinary code. So the "comms board" I showed earlier is most likely a code converter board. It contains multiple MC717 NOR gates and the wiring loom goes to the main board near the flip-flops discussed.
    There is another small mystery. There is no current limiting resistor on the bases of the 2N4409 HV transistors. This means that the design is relying on the collector pullup resistor of the RTL flip-flop to limit the current. The nominal value given in the datasheet is 3.6k. With a voltage supply of 3.6V and a B-E drop of 0.6V, this means a bit less than 1mA current drives the HV transistors. That is plausible. But there is another question: doesn't this load down the high level of the flip-flop so that it's not a true 1? Yes it does, but as the flip-flops are used as buffer latches and the outputs don't drive other RTL logic gates, this has no consequences. Obviously the designer did this deliberately and saved quite a few resistors this way. 👍
View all 12 project logs
paulpalomino2010 wrote 02/23/2022 at 17:32 point
You can use 74141 or the Russian version K155NA1 to drive the Nixies.
The MPS42A or 2N3439 are suitable driver transistors.
I restored a Heathkit IB-101 frequency counter with these components.
You can use a CD4013 dual D flip-flop for the divider.
Ken Yap wrote 02/23/2022 at 22:13 point
Nah, the HV driver transistors are already on board. No need for dividers, I will use a MCU to provide the time keeping.
Thomas wrote 01/04/2022 at 10:51 point
This really looks like "early 60s technology meets early 70s components". That's at least 50 years old technology ;-)
Ken Yap wrote 01/04/2022 at 10:55 point
Yes, I'm really enjoying this hardware archeology. I'm getting a feel for how things were like back then.
Thomas wrote 01/12/2022 at 20:38 point
Your findings about the 1:2:2':4 code are really interesting - I had no idea that it had ever been done like that. When I used 74141 decoders around 1978, those chips were already outdated!
Ken Yap wrote 01/12/2022 at 21:06 point
Yes, when silicon integration became able to create gates with many inputs, e.g. the multiple emitter transistor, the need to minimise the number of individual gates fell away, and industry standardised on binary or BCD encoding.
