kicad_pcb - 9.55 kB - 02/18/2022 at 18:29 |
step - 32.29 kB - 02/18/2022 at 18:29 |
main-NPTH.drl.5mm endmill for the needle holes, .8mm for the notches and header pinsdrl - 289.00 bytes - 01/23/2022 at 15:01 |
main-Edge_Cuts.gbrI used a 2mm endmill, but other sizes will workgbr - 875.00 bytes - 01/23/2022 at 15:01 |
socket.stlPrint with opening on the bedStandard Tesselated Geometry - 49.11 kB - 01/23/2022 at 15:00 |
Standard Tesselated Geometry - 2.43 kB - 01/21/2022 at 14:50 |
