Inverter Rear Wall.pdfTo-scale view of inverters, combiner boxes, battery shelves, and breaker panels for sizing/placement analysis. Also note Mr Reddy Kilowatt holding the kid at knifepoint. This is integral to the design and it's on order from Etsy.Adobe Portable Document Format - 619.27 kB - 01/27/2022 at 03:25 |
Shed Wall Studs.pdfIllustrates wall stud placement to align with James Hardie fiber cement exterior paneling.Adobe Portable Document Format - 293.46 kB - 01/27/2022 at 03:25 |
Blue ECO Carpet Just Because.pdfEverything EV-related has to be blue, hence blue carpet. Wanted something to protect the OSB flooring from damage, also protect my knees. Note the carpet is cheap but the glue isn't.Adobe Portable Document Format - 317.13 kB - 01/27/2022 at 03:25 |
Battery Shelves Overhead.pdfIllustrates how much space the 16S 2P arrays of 280Ah LFP batteries will consume.Adobe Portable Document Format - 362.51 kB - 01/27/2022 at 03:24 |
Roof Truss Gussets.pdfOptimal cuts for making rood truss gussets from OSB sheets. Want to be efficient with the expensive carbohydrate foam.... scrap can be used to build battery box.Adobe Portable Document Format - 242.54 kB - 01/27/2022 at 03:24 |
Hardie Backer Sketch.pdfManufacturer recommends cement backer behind inverters. Sounds smart, but Hardie Backer is oddball 3ft x 5ft sizes... Cuts TBD.Adobe Portable Document Format - 233.54 kB - 01/27/2022 at 03:24 |
Pressure Treat Forklift Skid Base.pdfDesign goal to make this shed semi-portable in case the lot placement doesn't work out in the future. Using ground-contact PT lumber for a skid. Note the highlighted center area is where plywood is to be put underneath to prevent tipping off the forks. Meant to be picket up from the heavy rear with the pair of 175 lb inverters.Adobe Portable Document Format - 453.66 kB - 01/27/2022 at 03:24 |
Battery Shelf Arrangements.pdfSketches of best terminal arrangements to get 16S 2P array or 16S 1P expandable to 2PAdobe Portable Document Format - 308.41 kB - 01/27/2022 at 03:24 |
Roof Appearance.pdfMade to match my existing sheds, garage, & house terra cotta colors. Shingles are hard to find right now!!!Adobe Portable Document Format - 227.71 kB - 01/27/2022 at 03:24 |
Floor Joists.pdfJoists above PT skid, for insulating the floor to keep batteries above low-temp cutoff. You could save a lot of money on lumber if you build on a concrete slab and forgo the PT lumber and these joists.Adobe Portable Document Format - 387.09 kB - 01/27/2022 at 03:24 |
Roof Trusses.pdfDimensioning for making optimal sized roof from 4x8 sheet goods.Adobe Portable Document Format - 258.81 kB - 01/27/2022 at 03:24 |
TOU Prices Winter.pngCalifornia SDGE Winter RatesPortable Network Graphics (PNG) - 483.43 kB - 01/22/2022 at 15:22 |
TOU Prices Summer.pngCalifornia SDGE Summer RatesPortable Network Graphics (PNG) - 464.25 kB - 01/22/2022 at 15:22 |
