Meshtastic Mesh Device Station Edition G1 has been released
A project log for Meshtastic Mesh Device Nano Edition
A compact Lora device with high efficiency internal compact Lora PCB Antenna, ultra-low noise figure amplifier and internal GPS module. This
neil-haoNeil Hao 08/02/2022 at 17:350 Comments
The Station Edition series is a compact Lora device with high power PA (Maximum TX Power: 35dBm@915MHz or 868MHz for Station G1 Edition), Rugged SMA Antenna Socket, rich external IO interface, wide input voltage range (8VDC-20VDC). This series aims to provide the best RF performance in all series with credit card size and rugged construction. Fixed-location base stations and vehicle-mounted base stations are typical application scenarios for this series.
For the firmware, Meshtastic firmware 1.2.65 is preinstalled. Meshtastic Mesh Device Station Edition G1 is expected to be merged into the official meshtastic repository on Github starting from firmware 1.3.
More Information:
https://hackaday.io/project/186654-meshtastic-mesh-device-station-edition-g1
