Connected trashcan project - presentation.pdfConnected trashcan - presentation slidesAdobe Portable Document Format - 8.66 MB - 06/02/2022 at 17:32 |
sensoring_script.pyPython script of the Raspberry Pi 4B/!\ Change the link to your own database inside py - 2.67 kB - 06/01/2022 at 09:22 |
HTML website.zipPack of all you need for the website/!\ Change the link to your own database in dashboard.html x-zip-compressed - 2.33 MB - 06/01/2022 at 09:21 |
wiring schem.PNGThe wiring schem of the projectPortable Network Graphics (PNG) - 75.58 kB - 05/28/2022 at 10:47 |
device box.svgYou need to make new holes :- one where you want the LED to be (5mm diameter) - one to have access to the battery and let the wires of the sensor pass (90x25mm) svg+xml - 10.06 kB - 05/28/2022 at 10:41 |
sensor box.svgYou also need to make holes :- one to let the cable pass (10x4mm) - one in front of each sensoring part of the sensor (1.5mm diameter) svg+xml - 6.85 kB - 05/28/2022 at 10:41 |
