FalseColorIRatn.atnPhotopea actions for false color infrared. Includes auto align and channel swapping.atn - 3.61 kB - 10/22/2022 at 01:37 |
FilterWheelBase4.stlBase that attaches to case back and holds filter wheel.Standard Tesselated Geometry - 210.82 kB - 10/20/2022 at 17:29 |
FilterWheelNut4.stlNut for under the filter wheelStandard Tesselated Geometry - 90.12 kB - 10/20/2022 at 17:28 |
Gerber_PCB_1wLEDModule_2022-09-15.zipGerber file for LED module prototype for surface mount LEDs. Includes through-hole points for testing with various resistors, potentiometers, and switches.x-zip-compressed - 9.85 kB - 10/20/2022 at 16:21 |
LEDmoduleTop1.stlThin diffuser top for LED modules. Printed in white.Standard Tesselated Geometry - 335.63 kB - 10/20/2022 at 16:18 |
CaseBack2.stlBack of case with holes for magnetic mount.Standard Tesselated Geometry - 632.02 kB - 10/20/2022 at 16:17 |
LEDmodule5.stlBottom of case for LED modules.Standard Tesselated Geometry - 103.21 kB - 10/20/2022 at 16:12 |
Case6.stlCase for Pixel 3a with hole for tripod mount.Standard Tesselated Geometry - 684.46 kB - 10/20/2022 at 16:09 |
FilterWheel6.stlFilter wheel for Vis, IR, UV, and Polarized photography.Standard Tesselated Geometry - 676.06 kB - 10/20/2022 at 16:09 |
BandpassFilterWheel1.stlFilter wheel for 10mm bandpass filters.Standard Tesselated Geometry - 655.94 kB - 10/20/2022 at 16:09 |
LEDmoduleTopUV.stlTop for UV light module, with hole for LEDs.Standard Tesselated Geometry - 276.64 kB - 10/20/2022 at 16:09 |
