Power line +5V installed
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 08/26/2018 at 19:480 Comments
Installed all cables support (printed them from ABS plastic). As you can see, second register block returned to it's place. It's done.
Next step is to connect VCC and GND to blocks and cut 16-pin cables.
For +5V power delivery 2mm^2 copper wire is used. Second wire (GND) - chassis.
