Techno-Shibari.
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 08/27/2018 at 17:170 Comments
Cut cables. Each cable is 20-bit width, bu I need 16-bit only. Need to install connectors on the one side and measured each cable.
