prometheus.pdfA draft copy of the text of the Description, Details, and Project Logs for this project in pdf form. Enjoy!Adobe Portable Document Format - 225.17 kB - 07/14/2022 at 12:12 |
pascal_procedures.pdfA somewhat more condensed version of the list of the procedures in the original UCSD Pascal compiler source code. Numbers next to the procedure name are not line numbers, rather they are the symbol numbers based on a version of the tokenizer that captures each symbol's index number as it is parsed. Quotation marks are added when the debugging code reports on the name of a variable, or string literal.Adobe Portable Document Format - 9.59 kB - 07/08/2022 at 07:57 |
UCSD Pascal 1.5 Compiler.pdfThis is the source code for the original UCSD Pascal 1.5 Compiler which was released for free, non-commercial and-or educational use by the University of California, San Diego sometime around 2003. I have taken the original text file from the UCSD distribution and added line numbers for reference purposes, as well as printing it out in pdf format.Adobe Portable Document Format - 221.37 kB - 06/27/2022 at 02:09 |
