Jar_Clock_Slave.X.production.hexHex file for the Slave MCUhex - 1.49 kB - 12/23/2016 at 21:34 |
Jar_Clock_Master.X.production.hexHex file for the Master MCUhex - 690.00 bytes - 12/23/2016 at 21:33 |
Extension button board.dipThe Layout for the small extension PCB for the buttons. This allows setting the time without touching the oil if you choose to fill the jar way up top with oil and it connects in the indicated place on the slave board padsdip - 10.52 kB - 12/13/2016 at 18:39 |
battery schematic.dchschematic file of the sealed accumulator connection inside the jar (DipTrace)dch - 22.49 kB - 11/30/2016 at 20:21 |
jar_clock_slave.asmASM code for the slave MCUasm - 5.28 kB - 11/30/2016 at 14:28 |
jar_clock_master.asmthe ASM code for the master MCUasm - 2.25 kB - 11/30/2016 at 14:28 |
jclock_schematic_redraw.dipThis is the layout file ( for DipTrace )dip - 197.72 kB - 11/30/2016 at 14:26 |
