vinyl_cutter_pen_holder-Bic_holder.stl- use this in place of the Graphtec cutter to do ballpoint drawing/plotting instead.Standard Tesselated Geometry - 129.28 kB - 12/17/2022 at 14:08 |
vinyl_cutter_holder-carriage.stl- clamp is retained using 2x M3 screws and threaded inserts- drill out holes for rails for sliding fit, e.g. I used 2.65mm dia. rails and a 2.8mm drill bit. Standard Tesselated Geometry - 310.43 kB - 08/12/2022 at 14:14 |
vinyl_cutter_holder-backplate.stl- attach to printer using 2x M3 screwsStandard Tesselated Geometry - 293.15 kB - 08/12/2022 at 14:14 |
vinyl_cutter_holder-retaining_clip.stl- use this to hold carriage/cutter up to avoid striking the bed.Standard Tesselated Geometry - 128.40 kB - 08/12/2022 at 14:14 |
