Pen plotter
A project log for Vinyl cutter for Ender 3 v2
An adaptor to allow a drag knife cutter to be fitted to an Ender 3 v2
robgRobG 12/17/2022 at 14:070 Comments
With one quick additional 3D-printed part, the vinyl cutter becomes a pen plotter!
Look for the 'Bic holder' STL in the files section. Simply remove the barrel from a cheap Bic ballpoint and stuff it in the hole. If the hole's too tight, open it out with a 4.0mm drill.
As before, use Gcodeplot for Inkscape to convert paths to GCode toolpaths and you're away...
