toggle-holder_countersunk.stlThis holds the toggle switches in place. I soldered little usb connectors to the switches so I can easily swap out whatever I want to power through the toggles.Standard Tesselated Geometry - 152.82 kB - 09/14/2022 at 21:27 |
umbilical-plugs_pack-side_01.stlA mounting plate for the 2 usb and full size hdmi female connectors that the umbilical plugs into on the pack side.Standard Tesselated Geometry - 283.68 kB - 09/09/2022 at 13:11 |
antennae-holder_mirror.stlSimple shape to follow the arc of the internal frame of the backpack, with some holes in it to screw antennae through. Or whatever else fits in the holes. LEDs, bolts etc.Standard Tesselated Geometry - 166.88 kB - 09/05/2022 at 17:57 |
cj-helmet-adapter.ailaser cut from aluminum: braces terminal components and has hole specifically designed to accept helmet holder on backpack so terminal can be securely stored on the exterior of the pack.postscript - 1.14 MB - 09/01/2022 at 14:36 |
cj-handle.ailaser cut from aluminum: screwed into core of terminal. Wooden handle screws into this.postscript - 1.14 MB - 09/01/2022 at 14:36 |
holder cap top.stlprinted with PLA: top part of cable enclosure for terminal female cables for solid positioning and allowing umbilical to securely plug in.Standard Tesselated Geometry - 65.90 kB - 09/01/2022 at 14:36 |
holder cap bottom.stlprinted with PLA: bottom part of cable enclosure for terminal female cables for solid positioning and allowing umbilical to securely plug in. Bottom also screws into terminal leg.Standard Tesselated Geometry - 73.52 kB - 09/01/2022 at 14:36 |
plug holder.stlprinted with PLA: central part of cable enclosure for terminal female cables for solid positioning and allowing umbilical to securely plug in.Standard Tesselated Geometry - 7.11 kB - 09/01/2022 at 14:36 |
