A drum machine based on a Faust code running on a teensy with the following features:
- Ideally 8 voices (probably more like 5)
- Individual triggers
- Mix output
- Individual output per voice which removes voice from mix when plugged in.
- Selectable “kit” parameter to select different voice presets. CV controllable.
- All knobs CV controllable
- Line output
- Eurorack output
- DC power
- Eurorack power
I need to test how complex I can make the Faust code and it still run smoothly on the Teensy, taking into consideration all the other processing that it will need to do.
Need to look at output scaling for Eurorack and line level.
Think initially I will make a pcb that a teensy can connect to directly, but eventually I may add the circuitry directly to the drum machine pcb.
Realising that I need to build this for Teensy 4.0 / 4.1 as other models are not available. This means less Ain pins but will have to do the multiplexing idea.
