Front view closed.jpgThe Keyboard is stored in front of the display for transport. Two latches can be pressed down on top and the keyboard can be removed from the package.JPEG Image - 9.11 MB - 09/20/2022 at 18:54 |
Locked display.jpgThe display is spring-loaded and held down by a pin in the bottom.JPEG Image - 10.13 MB - 09/20/2022 at 18:53 |
Tilted display.jpgOn press of the "TILT" button, and the pin is mechanically released, so the display can be tilted to the desired angle.JPEG Image - 9.74 MB - 09/20/2022 at 18:53 |
Back view.jpgOn the backside I made one big cutout, which is used as an exhaust for the hot air.JPEG Image - 9.36 MB - 09/20/2022 at 18:53 |
Right side opening.jpgThe back can be removed after undoing just 3 screws. 3 additional clips are located at the bottom.JPEG Image - 10.49 MB - 09/20/2022 at 18:53 |
Dust filtration.jpgMost of the air intake is handled by the old 5.25'' bay slots, which is therefor covered by a dust filter.JPEG Image - 9.38 MB - 09/20/2022 at 18:52 |
Removable parts.jpgOnce the back side is removed, the 3D printed part just slide in and out. Especially useful for the dust filter.JPEG Image - 11.11 MB - 09/20/2022 at 18:53 |
Pump fitment.jpgThe bottom part of the pump's cooler had to go, to make it fit onto the radiator.JPEG Image - 8.11 MB - 09/20/2022 at 18:53 |
Back view open.jpgIt is a pretty crammed setup and I wouldn't want to swap out a part, but it all fit in the end. Maybe I will go for a 360 mm radiator next time.JPEG Image - 10.71 MB - 09/20/2022 at 18:53 |
Fill port and display controls.jpgThe Fillport extension, so you are at least able to fill the loop and the display controls on top, in case you need to change some settings.JPEG Image - 9.83 MB - 09/20/2022 at 18:52 |
Anti-kink bracket.jpgThis little 3D printed thing, helps the tube stay in shape.JPEG Image - 10.31 MB - 09/20/2022 at 18:53 |
Left side view.jpgHere all the motherboards and GPUs IO is accessible. I also installed an additional 80 mm fan here to maintain some airflow over the mainbaord.JPEG Image - 9.08 MB - 09/20/2022 at 18:53 |
GPU IO ports.jpgA flat HDMi cable for the integrated display. The rest is accessible for external displays.JPEG Image - 8.51 MB - 09/20/2022 at 18:53 |
All working.jpgFor the complete setup, you are only missing the mouse (and headphones).JPEG Image - 11.90 MB - 09/20/2022 at 18:54 |
Heavy but portable.jpgThe overall package is quite heavy, but the sturdy handle holds all of it without a problem.JPEG Image - 10.38 MB - 09/20/2022 at 18:54 |
Front view open.jpgSame as the other picture, but without compression.JPEG Image - 9.33 MB - 09/20/2022 at 18:53 |
Parts and pieces.zipHere are some of the more useful parts in Fusion 360 and STL format. This is only the V1 and I barely even manged to complete it, but I am happy to help if you are doing something similar.x-zip-compressed - 1.75 MB - 09/20/2022 at 19:39 |
