Rigol MSO2000 Waveform Generator Panel
This adapter Boards makes the MSO2000 AWG Connectors and the Trigger Output acessible from the Front. It also adds AC coupling
Public Chat
It is cumbersome to use the signal generator and trigger output connectors on Rigol's MSO2000 series because they are located on the back of the instrument.
With this small board they are now also accessible from the front. I also added the feature of a switchable AC coupling for the two signal generator outputs.
x-zip-compressed - 26.54 kB - 11/21/2022 at 07:20
Download
