First manual melting test
12/02/2022 at 20:27 • 0 commentsWe made a simple melting test with a torchlight which heated up a metal profile. The sheets have been pushed against the heated profile. After a while we removed the profile and pushed the sheets against each other.
The connection between the sheets was okay but could be stonger if we would use some sort of more professional machine-process. So, lets build a machine....
