A89301.pyPython module for controlling the IC through an MCP2221A (can definitely be ported)x-python - 8.09 kB - 11/21/2023 at 23:00 |
PCB_PCB_Qwiic BLDC copy_2023-11-21.jsonPCB design for higher power version (import to easyeda)JavaScript Object Notation (JSON) - 567.71 kB - 11/21/2023 at 22:56 |
SCH_Qwiic BLDC higher power_2023-11-21.jsonSchematic for higher power version (import to easyeda)JavaScript Object Notation (JSON) - 97.78 kB - 11/21/2023 at 22:55 |
Gerber_PCB_Qwiic BLDC.zipGerber for the non-higher-current versionx-zip-compressed - 82.67 kB - 01/20/2023 at 00:04 |
PCB_PCB_Qwiic BLDC HC_2023-01-19.jsonEasy EDA json (import) for the higher current versionJavaScript Object Notation (JSON) - 567.71 kB - 01/20/2023 at 00:02 |
PCB_PCB_Qwiic BLDC_2023-01-19.pdfPDF PCB layout for the non-higher-current versionAdobe Portable Document Format - 323.83 kB - 01/20/2023 at 00:02 |
PCB_PCB_Qwiic BLDC_2023-01-19.jsonEasy EDA json (import) for the non-higher-current versionJavaScript Object Notation (JSON) - 578.97 kB - 01/20/2023 at 00:02 |
PCB_PCB_Qwiic BLDC HC_2023-01-19.pdfPDF PCB layout for the higher current versionAdobe Portable Document Format - 323.86 kB - 01/20/2023 at 00:02 |
Schematic_Qwiic BLDC HC_2023-01-19.pdfSchematic for the higher current versionAdobe Portable Document Format - 95.87 kB - 01/20/2023 at 00:02 |
Schematic_Qwiic BLDC_2023-01-19.pdfSchematic for the non-higher-current versionAdobe Portable Document Format - 93.23 kB - 01/20/2023 at 00:02 |
Gerber_PCB_Qwiic BLDC HC.zipGerber for the higher current versionx-zip-compressed - 90.74 kB - 01/20/2023 at 00:02 |
