preload.stlThe carriage with a place to mount roller bearings to preload the IGUS linear slide. 3D print this.Standard Tesselated Geometry - 159.75 kB - 01/20/2017 at 23:15 |
PrinterAllDXF.dxfAll The DXF files for cutting, all from 6mm wood stock, other than the roughly A4 sheet with 4 holes. That should be transparent dark red acrylic.AutoCAD DXF - 502.77 kB - 01/20/2017 at 23:13 |
