Hedy MCU
IOT based programmable Microcontroller unit
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Hedy MCU is a IOT based microcontroller board which can be programmed to perform various tasks and applications. Apart from that it has a programmable RGB led which can reflect more than 16M colors from it's eyes. It has 11 digital and 1 Analog pins. The design of the board makes the board very unique and when mounted in projects, it makes them look way more cooler. It also has a Android App which can control all the digital pins and read the analog pin an display it's value. The name of the Board is Inspired from the mother of wi-fi Hedy Lamarr as the board has in-built wi-fi.
