Lead screwV2.SLDPRTplease see assembly file and opensldprt - 3.44 MB - 06/21/2023 at 05:17 |
Chassis_BottomAA.SLDPRTplease see assembly file and opensldprt - 49.17 kB - 06/21/2023 at 05:17 |
Pan_sillicone Stirrer.SLDASMplease see assembly file and opensldasm - 849.49 kB - 06/21/2023 at 05:17 |
Nut PlateV2.SLDPRTplease see assembly file and opensldprt - 79.57 kB - 06/21/2023 at 05:17 |
Motor mountAA.SLDPRTplease see assembly file and opensldprt - 91.84 kB - 06/21/2023 at 05:17 |
Assem3.SLDASMplease see assembly file and opensldasm - 2.18 MB - 06/21/2023 at 05:17 |
Prestige Kadai 240.PDFplease see assembly file and openAdobe Portable Document Format - 32.42 kB - 06/21/2023 at 05:17 |
inductionCooker v1AA.SLDPRTplease see assembly file and opensldprt - 235.52 kB - 06/21/2023 at 05:17 |
Nut PlateV2AA.SLDPRTplease see assembly file and opensldprt - 80.21 kB - 06/21/2023 at 05:17 |
NoshMini_PoC1_Assembly.SLDASMplease see assembly file and opensldasm - 3.75 MB - 06/21/2023 at 05:17 |
Motor mount.SLDPRTplease see assembly file and opensldprt - 91.30 kB - 06/21/2023 at 05:17 |
Top block.SLDPRTplease see assembly file and opensldprt - 50.77 kB - 06/21/2023 at 05:17 |
Bottom blockAA.SLDPRTplease see assembly file and opensldprt - 133.52 kB - 06/21/2023 at 05:17 |
Chassis_Bottom.SLDPRTplease see assembly file and opensldprt - 49.17 kB - 06/21/2023 at 05:17 |
NoshMini_PoC1_AssemblyAA.SLDASMplease see assembly file and opensldasm - 3.75 MB - 06/21/2023 at 05:17 |
Induction_AssemblyAA.SLDASMplease see assembly file and opensldasm - 122.82 kB - 06/21/2023 at 05:17 |
Pan_sillicone StirrerAA.SLDASMplease see assembly file and opensldasm - 849.49 kB - 06/21/2023 at 05:17 |
Cover.SLDPRTplease see assembly file and opensldprt - 40.85 kB - 06/21/2023 at 05:17 |
Induction_Assembly.SLDASMplease see assembly file and opensldasm - 122.82 kB - 06/21/2023 at 05:17 |
Assem3AA.SLDASMplease see assembly file and opensldasm - 2.18 MB - 06/21/2023 at 05:17 |
Lead screwV2AA.SLDPRTplease see assembly file and opensldprt - 3.44 MB - 06/21/2023 at 05:17 |
Handle.SLDPRTplease see assembly file and opensldprt - 61.42 kB - 06/21/2023 at 05:17 |
Guide ShaftV2.SLDPRTplease see assembly file and opensldprt - 30.41 kB - 06/21/2023 at 05:17 |
Middle block.SLDPRTplease see assembly file and opensldprt - 105.13 kB - 06/21/2023 at 05:17 |
Prestige Kadai 240AA.SLDPRTplease see assembly file and opensldprt - 6.83 MB - 06/21/2023 at 05:17 |
Stirrer Blade Shaft.SLDPRTplease see assembly file and opensldprt - 69.64 kB - 06/21/2023 at 05:17 |
HandleAA.SLDPRTplease see assembly file and opensldprt - 61.42 kB - 06/21/2023 at 05:17 |
Middle blockAA.SLDPRTplease see assembly file and opensldprt - 105.97 kB - 06/21/2023 at 05:17 |
Prestige Kadai 240.SLDPRTplease see assembly file and opensldprt - 6.97 MB - 06/21/2023 at 05:17 |
CoverAA.SLDPRTplease see assembly file and opensldprt - 40.85 kB - 06/21/2023 at 05:17 |
Chassis_StemAA.SLDPRTplease see assembly file and opensldprt - 411.78 kB - 06/21/2023 at 05:17 |
Stirrer Blade ShaftAA.SLDPRTplease see assembly file and opensldprt - 69.64 kB - 06/21/2023 at 05:17 |
Z as koppeling 5-8AA.SLDPRTplease see assembly file and opensldprt - 297.46 kB - 06/21/2023 at 05:17 |
Worm Drive Motor JGY370V2.SLDPRTplease see assembly file and opensldprt - 275.13 kB - 06/21/2023 at 05:17 |
Z as koppeling 5-8.SLDPRTplease see assembly file and opensldprt - 297.46 kB - 06/21/2023 at 05:17 |
Guide ShaftV2AA.SLDPRTplease see assembly file and opensldprt - 30.41 kB - 06/21/2023 at 05:17 |
inductionCooker v1.SLDPRTplease see assembly file and opensldprt - 307.32 kB - 06/21/2023 at 05:17 |
Stirrer V1 Overmolded AA.SLDPRTplease see assembly file and opensldprt - 1.54 MB - 06/21/2023 at 05:17 |
Bottom block.SLDPRTplease see assembly file and opensldprt - 134.47 kB - 06/21/2023 at 05:17 |
Stirrer V1 Overmolded .SLDPRTplease see assembly file and opensldprt - 1.54 MB - 06/21/2023 at 05:17 |
Chassis_Stem.SLDPRTplease see assembly file and opensldprt - 411.80 kB - 06/21/2023 at 05:17 |
Prestige Kadai 240.SLDDRWplease see assembly file and openslddrw - 123.68 kB - 06/21/2023 at 05:17 |
Worm Drive Motor JGY370V2AA.SLDPRTplease see assembly file and opensldprt - 275.13 kB - 06/21/2023 at 05:17 |
Top blockAA.SLDPRTplease see assembly file and opensldprt - 50.77 kB - 06/21/2023 at 05:17 |
future nova proto.mp4This is the video of how it works and the way how it helps a user to help in assistive cookingMPEG-4 Video - 8.05 MB - 05/24/2023 at 05:49 |
