Estimated Bill of Materials
01/28/2024 at 20:50 • 0 commentsBe aware that putting this together, even without prototyping expenses as the "end-user", will be more expensive than buying the MacBook Pro 16. This is a project for the passionate!
Below is a rough cost estimate in the configuration that I plan on using:
Sub-Total: $2504
Base laptop
- We do not need the first-party keyboard, trackpad, or screen, but buying only the required parts from the marketplace does not save us money over the DIY edition.
- Added benefit that you can revert to the first-party parts if the mod does not work out for you.
$1399 Framework Laptop DIY Edition with Ryzen 7 7840HS $80 6x Expansion Cards $200 4TB NVME SSD (Amazon) $85 32GB DDR5 SODIMM (eBay) $60 USB-C PD Charger (Amazon) Display Assembly and Palmrest
$300 3D-printed palmrest and display bezel pieces in ABS (outsourced) $100 1920x1200 14-inch matte IPS LCD (eBay) Keyboard
$80 110-pack Kailh Choc low-profile switches (Amazon) $70 Full set of Kailh Choc keycaps (Aliexpress) $50 Keyboard PCB(s) and supporting components (PcbWay) $10 RP2040 Microcontroller (eBay) $20 TrackPoint module - We do not need the first-party keyboard, trackpad, or screen, but buying only the required parts from the marketplace does not save us money over the DIY edition.
Theoretical approach to an extended battery
11/10/2023 at 22:47 • 2 commentsI have been spoiled for choice when it comes to batteries on older ThinkPads. At present, Framework laptops have only one internal battery that is rumored to be middling in terms of capacity relative to power consumption and not swappable without tools.
Assuming no other third parties release a battery pack for the Framework 16 expansion bay in the next 5 years and the expansion bay power delivery system supports charging input, I may consider building my own based on the guide: https://www.instructables.com/Battery-Powered-Raspberry-Pi-in-Repurposed-Laptop/
Mostly just a note to myself so I don't just forget about the work of a very dedicated Raspberry Pi owner to make SMBus charging work for him. I say this because I had long thought that making my own battery pack that reports battery percentage to the OS would be unrealistic.
Preliminary Timeline
07/17/2023 at 20:29 • 0 commentsI do want to have an upgrade to my aging X230 laptop ready in the next couple of years, so
- I don't anticipate this fizzling out, added that I refuse to give up the TrackPoint and classic keyboard
- I do anticipate the timeline changing depending on my available free time
Here's the timeline on my mind:
Spring 2024: I get my hands on the Framework 16 laptop
Summer 2024: Make measurements, test out parts, start playing with CAD
Fall 2024: Start running test prints and fine tune parts
Winter 2024: Put everything together, final testing and fitting, take glamour shots, polish up the write-up, and publish everything
Mid-2025: Probable actual completion date. Good thing that Framework promises to release case-compatible mainboard updates so this won't immediately become irrelevant once I finish.
