Bindig_post_core.pdfMechanical drawing of binding post, used to turn your own binding postsAdobe Portable Document Format - 78.23 kB - 06/28/2023 at 12:56 |
Standard Tesselated Geometry - 678.40 kB - 06/28/2023 at 12:54 |
Standard Tesselated Geometry - 216.78 kB - 06/28/2023 at 12:54 |
Standard Tesselated Geometry - 134.65 kB - 06/28/2023 at 12:54 |
Standard Tesselated Geometry - 153.01 kB - 06/28/2023 at 12:54 |
Standard Tesselated Geometry - 190.61 kB - 06/28/2023 at 12:54 |
Standard Tesselated Geometry - 54.38 kB - 06/28/2023 at 12:54 |
BlueSmoke.uf2Software for the onboard RP2040uf2 - 880.00 kB - 06/28/2023 at 11:42 |
CLP.csvdeskribes positioning of the components on the PCB. Used by PCB manufactorer in assembly so that they know where every componet goes.Comma-Separated Values - 9.35 kB - 06/28/2023 at 11:40 |
BOM.csvBill of Materials. List of all components on the PCB. Used when ordering components.Comma-Separated Values - 6.16 kB - 06/28/2023 at 11:40 |
rev_13.pdfSchematics. Used in debuging or if you just want to know how the electronics worksAdobe Portable Document Format - 919.84 kB - 06/28/2023 at 11:39 |
rev_13.rarGerber files. Send this to a pcb manufactorer, and they will know how to print the pcb.RAR Archive - 157.83 kB - 06/28/2023 at 11:39 |
