b800es_left_control_mount_a.stlMount for Gaggiuino screen. Part A attaches to the chassis using the original mounting bosses and original screwsStandard Tesselated Geometry - 220.79 kB - 08/07/2023 at 06:22 |
b800es_left_control_mount_d.stlMount for Gaggiuino screen. Part D attaches to parts Part C and B with M3x16 socket head screws and M3 threaded insertsStandard Tesselated Geometry - 228.99 kB - 08/07/2023 at 06:22 |
b800es_left_control_mount_b.stlMount for Gaggiuino screen. Part B attaches to Part A using a M4x25mm socket head screw and nut. This does not require any modification of the chassis and uses the original holes for the buttonsStandard Tesselated Geometry - 265.12 kB - 08/07/2023 at 06:22 |
b800es_left_control_mount_c.stlMount for Gaggiuino screen. Part C is a spacer between the front plate (part D) and the back plate (part B)Standard Tesselated Geometry - 103.21 kB - 08/07/2023 at 06:22 |
b800es_right_control_mount_b.stlMount for power and steam switches. Part B attaches to Part A using M4x25mm socket head screws and nuts. This does not require any modification of the chassis and uses the original holes for the buttonsStandard Tesselated Geometry - 339.14 kB - 08/07/2023 at 06:10 |
b800es_right_control_mount_c.stlMount for power and steam switches. Part C contains the power and steam rocker switches, and attaches to Part B with M3x16 socket head screws and M3 threaded insertsStandard Tesselated Geometry - 180.16 kB - 08/07/2023 at 06:10 |
b800es_right_control_mount_a.stlMount for power and steam switches. Part A attaches to the chassis using the original mounting bosses and original screwsStandard Tesselated Geometry - 244.61 kB - 08/07/2023 at 06:10 |
b800es_power_mount.stlMount for SSR, time delay cutoff relay, and terminal block. This screws onto the mounting bosses for the original electronics control boardStandard Tesselated Geometry - 198.23 kB - 08/07/2023 at 06:08 |
mount_box.stlMounting box for Gaggiuino electronics. Mates with a clear project box lid to provide better mains isolationStandard Tesselated Geometry - 3.24 MB - 08/07/2023 at 06:08 |
