STLINK-V2-TYPE-C-R0.zipFirst revision: Gerber + LCSC BoM + JLCPCB P&P files.Status: everything works properly. Assembly recommendations: Black solder mask, single-sided assembly, 1.2-2mm thick. x-zip-compressed - 165.16 kB - 10/03/2023 at 13:59 |
STLINK-V2-TYPE-C-R1.zipSecond revision: Gerber + LCSC BoM + JLCPCB P&P files.Condition: not tested, there is a risk of problems. Assembly recommendations: Black solder mask, single-sided assembly, thickness 1,2-2 mm. Improvements: higher transit current, better ESD and current protection, reduced size. x-zip-compressed - 222.15 kB - 10/03/2023 at 14:18 |
