M8B
Magic 8 Ball + User Guide
Our project is to create a Magic 8 Ball, as well as its users' guide.
The M8B will be able to give a random answer to a question asked by the user and the manual will light up automatically after opening it, to read the instructions.
Our M8B is very simple to use:
1)  Read the magical instructions book!
2) Touch the sensor to displays your answer on the screen.
To create it, we used several components:
  • 3 LEDs
  • 2 ESP32 TTGO LilyGo
  • A touch sensor keyestudio
  • Breadboard
  • Cables
  • Cardboard
  • Staples
MPEG-4 Video - 2.01 MB - 05/23/2024 at 09:11
Download
MPEG-4 Video - 33.06 MB - 01/12/2024 at 15:07
Download
Last test before finition.mp4
Instructions book
MPEG-4 Video - 19.20 MB - 01/12/2024 at 14:52
Download
Battery Test.MOV
connecting the rechargeable battery and the LED band
quicktime - 27.81 MB - 01/12/2024 at 12:05
Download
Switch V2.mp4
Sliding switch to light up the LEDs, here we can see that when pulling the string it light up
MPEG-4 Video - 10.53 MB - 11/30/2023 at 09:05
Download
View all 7 files
  • 1 × Touch Sensor 0100442 Magic 8 Ball
  • 2 × ESP 32 TTGO
  • 1 × Cardboard Everything
  • 1 × 08x02 LCD screen
  • 1 × Cord/string Instruction Book - switch
View all 18 components
  • Instruction book Final Demo
    Nelithzederdelle4 days ago 0 comments
    see the files
  • Final Code
    isaure.jarry01/12/2024 at 15:17 0 comments
    For the screen and the touch sensor:
    #include <Wire.h>
    #include <LiquidCrystal.h>
    const int rs = 15;
    const int en = 13;
    const int d4 = 32;
    const int d5 = 33;
    const int d6 = 25;
    const int d7 = 26;
    const int touchPin = 17;
    LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
    void setup() {
      lcd.begin(8, 2);
      pinMode(touchPin, INPUT);
      Serial.begin(115200);
      lcd.clear();
    void loop() {
      if (digitalRead(touchPin) == HIGH) {
        Serial.println("touch detected");
        lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print(getRandomMessage());
      lcd.setCursor(0, 1);
      lcd.print("UwU");
      delay(3,000);
        lcd.clear();
    bool screenOn = false;
    String getRandomMessage() {
      String messages[] = {
        "Go ahead",
        "fuck it.",
        "WTF?!",
        "OOPS",
        "Possibly",
        "Fate.",
        "Nauwr",
        "Shut up",
        "RIP",
        "Nope"
      int index = random(10);
      return messages[index];
    For the LEDs:
    const int redPin = 13;
    const int bluePin = 12;
    const int greenPin = 15;
    void setup() {
      pinMode(redPin, OUTPUT);
      pinMode(bluePin, OUTPUT);
      pinMode(greenPin, OUTPUT);
      digitalWrite(redPin, LOW);
      digitalWrite(bluePin, LOW);
      digitalWrite(greenPin, LOW);
    void loop() {
      sequentialLEDs();
    void sequentialLEDs() {
      // Red LED on
      digitalWrite(redPin, HIGH);
      delay(500);
      // Blue LED on
      digitalWrite(bluePin, HIGH);
      delay(500);
      // Green LED on
      digitalWrite(greenPin, HIGH);
      delay(500);
  • Instruction book - 5th Log
    Nelithzederdelle01/12/2024 at 14:57 0 comments
    Final assembling and adjusting
    see videos in the files "Last test before finition
    Final aesthetic touches
    We decided to make a book cover to make the book more aesthetically pleasing.
    Step 1 : trace and baguettes
    Step 2 : glue fabric
    Step 3 : glue magnets
    Step 4 : cover
  • 2023-12-21
    isaure.jarry12/21/2023 at 11:44 0 comments
    We successfully managed to display "Hello!" on our LCD screen, which is connected to the ESP32.
    Here is the code:
    // Pin numbers for the LCD
    const int rs = 15;
    const int en = 13;
    const int d4 = 32;
    const int d5 = 33;
    const int d6 = 25;
    const int d7 = 26;
    // Create a LiquidCrystal object
    void setup() {
      // Initializing the LCD with its number of columns and rows, knowing ours is a 0802A
      lcd.begin(8, 2);
    void loop() {
      lcd.clear();          // Clear the LCD
      lcd.print("Hello!");   // Print a message
      delay(1000);           // Wait for a second
    These are our wirings:
    And this is the display:
  • 2023-12-14
    isaure.jarry12/14/2023 at 10:52 0 comments
    Today, we soldered the pins of the ESP32, so that the circuit can actually properly work.
  • 2023-12-07
    isaure.jarry12/07/2023 at 10:56 0 comments
    Today, we finished cutting all the parts for our first dome and tried to put them together using orthodontics latex elastics.
    How we put the elastics:
    Hexagons:
    Pentagons:
    When we assemble them:
    After that, we decided that the elastics would stay on better if we cutted nocks at the peaks of each triangle.
    We also came to the conclusion that the strips would be on the outside rather than inside because, as cardboard is a steady material, it doesn't stay in place is the strips are inside and we're afraid the elastics will just suddenly pop out.
    We'll probably paint the ball so that its surface is uniform.
  • 2023-11-30
    isaure.jarry11/30/2023 at 13:34 0 comments
    Today, we mainly worked on the conception of the ball.
    We want to choose cardboard as our material and fix it with horse elastics.
    Our inspiration:
    "MERCI" by Adrien Ciejack and Capucine Théry
  • Instruction book - 4th Log
    Nelithzederdelle11/30/2023 at 10:35 0 comments
    How to incorporate the rechargeable battery:
    Theoretical approach:
    HomeMade DIY HowTo Make: Technique to identify USB female port connector positive and negative polarity (howtodosteps.blogspot.com)
    Testing
    Wire the rechargeable battery to test if the LEDs shine bright.
    ------------------------- see the Battery Test video in the files -------------------------
    Practical application
    Cables needed (half : cable + port) :
    - 3 USB Male
    - 1 USB female
    - 1 micro USB
    Other components :
    - Cardboard
    - LED strip lights
    - sliding switch (explained in the previous log)
    - support (here is hard dry sponge but can be cork or anything)
    - pins support, to hold the switch in place
    Notice:
    We removed the spring from the sliding switch because it was too strong.
    So we used some elastic string instead.
  • Instruction book - 3rd Log
    Nelithzederdelle11/30/2023 at 10:03 0 comments
    Sketch of the Instruction page:
    Sent to cut in the laser cutter machine
  • 2023-11-23
    isaure.jarry11/23/2023 at 09:16 0 comments
    We uploaded the following videos on our feed:
    • Sliding switch to light up the LEDs when we open the instructions book.
    • Testing the code for the loading LEDs of the Magic 8 Ball.
    We wrote the code (working) for the loading LEDs of the ball :
    const int touchPin = 33;
    const int bluePin = 2;
    void setup() {
    void loop() {
      int touchValue = touchRead(touchPin);
      if (touchValue < 1000) {
      delay(500);
      delay(500);
      delay(500);
    As a reminder, it will be used when the answer to the question asked by the user will be uploading, symbolised by the lights lighting up in a row.
    We also looked for the materials that we don't have yet, such as the ball, the magnets, etc. Everything that isn't electronic.
View all 17 project logs
  • 1
    Cardboard prototype
  • 2
    Learn about all the components
    • Draw schemes of the functionning of each component and of the circuits
    • Read data sheets online
    • Realise simple codes, for instance using the ESP32
  • 3
    Coding
View all 6 instructions
