How to incorporate the rechargeable battery:
Theoretical approach:
Testing
Wire the rechargeable battery to test if the LEDs shine bright.
------------------------- see the Battery Test video in the files -------------------------
Practical application
Cables needed (half : cable + port) :
- 3 USB Male
- 1 USB female
- 1 micro USB
Other components :
- Cardboard
- LED strip lights
- sliding switch (explained in the previous log)
- support (here is hard dry sponge but can be cork or anything)
- pins support, to hold the switch in place
Notice:
We removed the spring from the sliding switch because it was too strong.
So we used some elastic string instead.
