First assembly test
11/05/2023 at 22:30 • 0 commentsNot yet finished...but every thing fits mechanically. The empty prototype board is for the level shifting. You can also see the Eurorack Power connector on that. The Blue Module is al little LM317 LDO which will probably use to generate some supply voltage for the Badge. The Badge than gets powered via the SAO Header on the front. See also the red and brown cable on the images.
Basic Idea an some CAD
11/05/2023 at 18:14 • 0 commentsThe badge does have two inputs and two outputs, which can be seen as 0-3V Audio. So convert this to some more Eurorack compatible Levels (still not sure what are the right levels) and make them available on some 3.5mm audio jacks. Than you need some cariiere to mount the Badge in your rack. This is what I cam up with:
First a Badge is needed
11/05/2023 at 18:03 • 0 commentsAs I am not attending this year's Supercon, I build my own badge. Boardfiles and BOM are available on this github: https://github.com/Hack-a-Day/Vectorscope and with some help of @davedarko I got my rebuild sourced, assembled and running.
