fogmachine2.yamlESPHome configuration file for wi-fi fog machineyaml - 1.02 kB - 10/31/2023 at 09:10 |
halloweencontroller1.yamlESPHome configuration file for main Halloween controller board.yaml - 5.98 kB - 10/31/2023 at 09:10 |
Motion Sensor Enclosure Assembly - Top Cover-1.STLMotion sensor enclosure top cover.Standard Tesselated Geometry - 1.05 MB - 10/31/2023 at 09:07 |
Motion Sensor Enclosure Assembly - Bottom Cover-1.STLMotion sensor enclosure bottom cover.Standard Tesselated Geometry - 768.15 kB - 10/31/2023 at 09:07 |
Motion Sensor Enclosure Assembly - Lens 0.75-1.STLMotion sensor enclosure snap-on lens.Standard Tesselated Geometry - 89.54 kB - 10/31/2023 at 09:07 |
Controller Enclosure Assembly - Gasket-1.STLRubber gasket for the main controller box enclosure designed to be printed on an Elegoo Saturn 2 with SuperFlex material.Standard Tesselated Geometry - 4.86 MB - 10/31/2023 at 09:07 |
Controller Enclosure Assembly - Bottom-1.STLMain controller box enclosure bottom half.Standard Tesselated Geometry - 613.95 kB - 10/31/2023 at 09:07 |
Controller Enclosure Assembly - Top-1.STLMain controller box enclosure top half.Standard Tesselated Geometry - 438.17 kB - 10/31/2023 at 09:07 |
Cauldron Handle.STLAesthetic handles to glue onto the sides of the cauldron. Print 2 of these.Standard Tesselated Geometry - 4.75 MB - 10/31/2023 at 09:07 |
Cauldron Quarter.STLThe cauldron body itself. 4 of these make up one complete cauldron. Originally designed to be printed on an Ultimaker S5.Standard Tesselated Geometry - 4.94 MB - 10/31/2023 at 09:07 |
