Crochet Cat Lamp
A cute crochet cat plushie with a colorful light up tail!
Combining crochet and electronics to create a cute cat companion that lights up your day!
As a computer engineering student, I've been wanting to find a creative way of combining my electronics and prototyping skills with my hobby of crochet. After attending the PCB Lamp Workshop at UCSD hosted by Supplyframe (https://hackaday.io/project/192881-pcb-lamp-workshop-arduino-edition), I set out to design a lamp in the form of a cat. This adorable cat's light up tail changes color by tilting the cat, and it has buttons in the front paws to control the light brightness and color mode (see more details in the section below).
This project was also inspired by the crochet kit shop Mochi Chums (https://mochichums.com/), which I recently started with my brother. Maybe this could be an idea for a future kit that teaches the fun of both crochet and electronics!
Design
I started by designing around the provided PCB boards, which included the controller board and the lamp board (I chose the straight line shape to match the shape of the tail).
I designed a 3D printed enclosure for the controller board, which became the body of the cat. This enclosure was also important to protect the electronics from the yarn and stuffing. Because I wanted to be able to easily access the controller board inside the case (such as to connect other components or change the batteries), I added a sliding lid that can be opened at the bottom of the cat. The PCB board is mounted upside down inside the case with screws.
The lamp board is connected to the controller board with a flexible ribbon cable, which forms the tail of the cat. I wanted the tail to be bendable, so I added metal wire to support and hold up the lamp board inside the tail.
To make the cat lamp more fun and interactive, I added push buttons in each of the front paws to control the LED brightness and color mode.
Finally, I crocheted around all of these components to form the shape of the cat plushie!
LED Brightness
The left paw push button toggles between 5 levels of brightness (0%, 25%, 50%, 75%, 100%).
LED Color Modes
The right paw push button toggles between two color modes.
  • Color Mode 1: the LEDs change color based on the direction and angle that the cat is tilted. This color mode takes advantage of the built-in accelerometer on the Arduino Nano BLE 33 Sense Rev2
  • Color Mode 2: the LEDs are fixed at a particular color. To set the LED color, press the color mode button while the cat is tilted at the desire color. In this fixed color mode, the lamp will stay at the selected color (even when tilting the cat) until the button is pressed again to switch back to color mode 1.
Project Skills
  • Soldering
  • CAD (Onshape)
  • 3D printing
  • Coding (Arduino)
  • Crochet
CrochetCatLamp.ino
Arduino Code
ino - 3.34 kB - 04/21/2024 at 02:22
Download
ControllerBox.stl
Controller Board Box
Standard Tesselated Geometry - 982.11 kB - 04/21/2024 at 02:25
Download
ControllerLid.stl
Standard Tesselated Geometry - 684.00 bytes - 04/21/2024 at 02:25
Download
ButtonBox.stl
Push Button Box
Standard Tesselated Geometry - 32.89 kB - 04/21/2024 at 02:25
Download
ButtonCover.stl
Push Button Box
Standard Tesselated Geometry - 557.31 kB - 04/21/2024 at 02:26
Download
  • 1 × Controller Board Arduino Nano BLE 33 Sense Rev2 & Battery holders (3 'AA')
  • 1 × Lamp Board Straight line shape with four LED's
  • 1 × Ribbon Cable 10" CABLE (FFC/FPC 6POS 1MM)
  • 4 × M3x6 Screws
  • 1 × Controller Case 3D printed
View all 12 components
  • 1
    Controller Board Case
    Paper prototype
    CAD model for controller board case
    3D printing controller board case
    Final 3D printed case (with soldered battery holders and header pins)
    Final 3D printed case with lid
  • 2
    Push Buttons for Cat Legs
    CAD model for button case
    Cross section view of CAD model
    Solder 2 female jumper wires to push button
    Push button inside 3D printed case
    Push buttons with cap and 3D printed lid
  • 3
    Cat Tail
    Wrap wire around back of lamp PCB board
    Braid wire along length of ribbon cable
    Crochet tail to fit lamp PCB board, ribbon cable, and wire
View all 6 instructions
