Vulcan_Salute.zipFastLED+ESP8266 webserver plus browser appx-zip-compressed - 282.82 kB - 03/07/2017 at 11:58 |
Tiny Pinion.stl8 tooth pinion gear. I printed in PETG for extra strength, but PLA is probably finesimplify3d_stl - 239.83 kB - 03/07/2017 at 04:24 |
Bullgear.stlBull gear with Vulcan salute flairsimplify3d_stl - 1.06 MB - 03/07/2017 at 11:59 |
Hambone Long.stlConnecting Rodsimplify3d_stl - 97.64 kB - 03/07/2017 at 04:24 |
Spacer Disc.stlTo add some space between the reflective backing and the moving fingerssimplify3d_stl - 7.89 kB - 03/07/2017 at 04:24 |
Spinner Badge.stlFor some extra Star Trek flairsimplify3d_stl - 174.30 kB - 03/07/2017 at 04:24 |
Geared Motor Mount shortened.stlMount was shortened to accommodate the large bullgearsimplify3d_stl - 60.82 kB - 03/07/2017 at 04:24 |
5V 4A power supply cover_new.stlCover for the metal encased power supply (option in the bill of materials)simplify3d_stl - 8.68 kB - 03/07/2017 at 04:24 |
Vulcan Salute Schematic.jpgWiring DiagramJPEG Image - 218.48 kB - 03/07/2017 at 04:24 |
Vulcan middle_and_index_plain.svgMiddle and index fingerThis scalable vector file can be imported into TinkerCad svg+xml - 4.08 kB - 02/13/2017 at 22:46 |
Vulcan pinky_and_ring_plain.svgPinky and ring fingerThis scalable vector file can be imported into TinkerCad svg+xml - 3.46 kB - 02/13/2017 at 22:46 |
Vulcan rest_of_hand_plain.svgThe rest of the hand. I did not import this, but this scalable vector file can be imported into TinkerCadsvg+xml - 5.11 kB - 02/13/2017 at 22:46 |
