SpiroBoardB06.pdf
Latest version of the schematic. Added optional screw terminal power input, larger sense resistor, and RC on sense resistor connections to ADC
Adobe Portable Document Format - 115.18 kB - 01/08/2019 at 21:26
Preview
Download
read_ec_ph.py
This opens the pigpio library and calls a function in spiroboard.py to read the EC and pH
plain - 1.43 kB - 09/06/2018 at 14:31
Download
spiroboard.py
This is a python file that uses the pigpio library to read the EC and pH from the Spiroboard
text/plain - 17.12 kB - 09/06/2018 at 14:25
Download
SpiroBoardB05.pdf
This is the schematic for the new sample-and-hold version of the design. The frequency and amplitude of the square waves used to measure the EC can be programmed through software on the RPi.
Adobe Portable Document Format - 106.64 kB - 07/17/2018 at 04:45
Preview
Download
spiroboarda04.pdf
This is the original schematic for the PC board. While debugging, I found a few problems that require a bit of surgery on the board. I will upload a new schematic when I have finished debugging, assuming that the patient lives.
Adobe Portable Document Format - 86.23 kB - 02/16/2017 at 13:54
Preview
Download
