image.jpegI hated the green, could they done it any worse. Had to be sorted. Son sprayed it primer grayJPEG Image - 1.91 MB - 02/24/2017 at 11:18 |
image.jpegFinished the cover for the battry & if need be I made it bobble out one side as if I do need or want to fit the 800w motor it will stick out that side as its a big motor . & u need to move things . I.e brake bit & sprocket & chain & so on . But it can be done .image/jpeg - 1.13 MB - 02/24/2017 at 13:48 |
