Day 14: Edge Board Color Sensor Board
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic 09/22/2023 at 18:070 Comments
Color Sensor board with the VEML6040 chip for color detection with built in led for low light situations.
This also has mousebites on the sensor part of the board so it can be removed and the color sensor can be mounted closer and in a smaller form factor than the larger assembly.
source files can be found here: https://github.com/evezor/v0_color_sensor_board
This board uses the Evezor Stamp STMF405 MCU
source: https://github.com/evezor/Evezor-Stamp-STMF405
