Day 15: Edge Board Low Power Mosfet Board
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic 09/23/2023 at 18:520 Comments
An edge board containing 3 low power mosfets capable of powering small loads like relays, small fans and LEDs. Also 3 buttons. Each output may be pulse width modulated. Power can come from the bus or external sources, selectable by jumper.
source files can be found here: https://github.com/evezor/v0_low_power_mosfet_board
This board uses the Evezor Stamp STMF405 MCU
source: https://github.com/evezor/Evezor-Stamp-STMF405
