Open Simple LIDAR
Open Source scanning laser rangefinder
This is simple enough open source scanning laser rangefinder. It is using triangulation method. It is based on my previous Lidar projects: http://hackaday.com/2016/06/05/in-soviet-russia-diy-laser-rangefinder-scan-you/ (https://github.com/iliasam/OpenLIDAR) and earlier lidar versions (in Russian): http://roboforum.ru/forum10/topic12095.html It is really cheap - its components cost less than $35 (without shipping).This Lidar can be very useful in robotics - for SLAM and navigation tasks.
This Lidar is using triangulation method for measuring distance to an objects. It can be shown by this picture:
Laser light is reflected by some object. Lens get part of that light and create an image of the laser dot at the image sensor (TSL1401). It can bee seen that the position of that image depends on distance to object.
Current Lidar parameters:
5 scans/second;
180 measurements per rotation (2 deg angle resolution);
Maximum distance - 4 m;
Measured accuracy now is - 5 cm at 2 m, 10 cm at 3 m (I hope that it can be improved).
I suppose that the price of all needed parts will be near $35 ($30 without interference optical filter) - without delivery price.
P.S. Sorry for my bad English - I am from non-English speaking country.
Video with testing this Lidar with Hector SLAM:
Another video:
Standard Tesselated Geometry - 238.04 kB - 10/01/2017 at 15:26
Download
Encoder ring drawing.
Portable Network Graphics (PNG) - 63.79 kB - 08/03/2017 at 17:10
Preview
Download
holder_v1.0.stl
3D model of the PCB holder.
Standard Tesselated Geometry - 263.01 kB - 08/03/2017 at 17:09
Download
laser_holder_v1.0.stl
3D model of the laser holder.
Standard Tesselated Geometry - 120.54 kB - 08/03/2017 at 17:09
Download
  • 1 × TSL1401CL Sensors / Image
  • 1 × Slip Ring Used to pass power and signals to rotating scanning head.
  • 1 × Encoder RPI-352
  • 1 × IR filter Interference bandpass filter
  • 1 × Small electrical and mechanical parts
View all 13 components
  • OpenSimpleLidar calibration
    iliasam05/26/2019 at 15:26 0 comments
    OpenSimpleLidar need calibration after assembling so I had made a video about it:
  • Published PC utility for Lidar testing
    iliasam05/04/2019 at 13:36 0 comments
    I have published PC utility for testing my Lidar:  "LidarScanningTest". It is published with its source files at the Github.
    Screenshot:
  • Autonomous robot moving with Open Simple Lidar
    iliasam04/17/2018 at 19:21 0 comments
    I write a special simple navigation node for the ROS called "simple_nav".
    Here is a video of robot autonomous moving to the given goal point:
  • Interference filter
    iliasam04/10/2018 at 18:45 0 comments
    I'm using interference filter in my lidar: https://en.wikipedia.org/wiki/Interference_filter
    It is used to decrease ambient light from different sources.
    Here is example of filter working:
    The left picture show influence of the lamp light (it is placed to the floor) to the Lidar image. Right picture was captured with filter installed.
  • Updated PCB
    iliasam03/04/2018 at 16:42 0 comments
    I have updated PCB of the Open Simple Lidar.
    I have routed and placed small motor board together with the main PCB of the lidar. Earlier that motor PCB must be produced separately, but now only one common PCB in needed to be produced.  Motor board must be cut from the main PCB before assembling the main PCB.
    Also I draw some descriptions for assembling PCB.
    New PCB image (motor PCB is on the left):
    Updated files: https://github.com/iliasam/OpenSimpleLidar/tree/master/PCB
  • Testing Lidar with ROS
    iliasam09/19/2017 at 18:44 0 comments
    I had installed my Open Simple Lidar to the old Roomba and tested it with ROS (including Hector SLAM):
    Photo of the lidar installed at the Roomba:
    The left board is Orange Pi PC running ROS nodes (Lidar node, Roomba node, Hector SLAM).
    All robot controlling was manual (using keyboard).
    The resulting map of the rooms:
    This map was created with a lidar working in 2 deg angular resolution mode.
    Also I had published Firmware code and lidar ROS node at the Github.
    Next step is increasing parameters of the Lidar by optimizing  its firmware.
  • Open Simple LIDAR is fully assembled!
    iliasam09/11/2017 at 19:14 0 comments
    Here is the photo of the assembled LIDAR:
    Last thing that I had installed is the small PCB with DC-DC converter for powering  motor.
    Photo of the installed board:
    This board also simplifies connections between LIDAR's components.
    Photo with the scanning head installed:
    Front view of the assembled LIDAR:
    My next step - write a node for ROS and to test SLAM algorithm.
  • First tests of my Lidar
    iliasam08/31/2017 at 11:47 0 comments
    I have done with basic firmware for my Lidar.
    There were some problem with encoder signals - UART communication produce some electrical noise at the encoder's line.
    Here is a video of first test:
    I decrease angle resolution to 2 deg to increase rotational speed - it is near 5 rotations per second.
    Circles at the "radar" images are 1, 2, 3 m in radius.
  • Testing encoder
    iliasam08/14/2017 at 18:14 0 comments
    I wrote a simple program for testing encoder. It's just blinking led at PCB when there is a hole in encoder disk.
    Photo of LIDAR with big exposure:
  • Assembling LIDAR
    iliasam08/13/2017 at 15:46 0 comments
    Now it is time to final LIDAR assembling.
    I have installed encoder to the "main plate", installed the PCB to the PCB holder, installed slip ring to the PCB holder, solder wires of the slip ring to the PCB pads.
    Photo of the assembled LIDAR:
    Side view:
    I have tested mechanics of the LIDAR - everything is working fine, the eccentricity of the LIDAR rotating head is not very big.
    Encoder is working fine too - oscilloscope shows  a good signal.
    Next steps are assembling small PCB for motor controlling and programming.
View all 16 project logs
seyda wrote 04/26/2020 at 12:02 point
hello which program do you use to programming to MCU? and also how do you programming MCU? Thank youu
mert.karaca wrote 10/14/2019 at 06:15 point
Dear Sir, I will make your LIDAR project form my senior project, ı wonder can I use M12 f16mm lens below product? https://uk.rs-online.com/web/p/video-modules/1633898/
Justin Qiu wrote 08/07/2018 at 18:42 point
I want to ask you a question regarding the pcb. What is the difference between  the v1.0 and v1.1?
iliasam wrote 08/07/2018 at 19:02 point
Thre were several small changes like C10 added, J2 SWD connector added.
josh zhao wrote 04/07/2018 at 09:54 point
That's really a great project !  How can I get the COMPONENTS online?
iliasam wrote 04/08/2018 at 15:07 point
See "TotalBOM" file at the https://github.com/iliasam/OpenSimpleLidar/
There are links to the most Lidar components.
Radu Motisan wrote 10/17/2017 at 10:48 point
love this! Congrats
Kristjan Berce wrote 08/26/2017 at 15:02 point
Would love to see a video of it working soon! :)
