PipeCam: Low-Cost Autonomous Underwater Camera
Back to overview
Low cost autonomous underwater camera for long term deployments and exploration
djgraff1 wrote 06/09/2019 at 20:20 point
I am working on this project. I use a tp5110 but I don't think it makes much difference for my purposes. Basically I found some errors in your code involving the path being wrong and also as you mentioned the shutdown process is a bit sloppy. I also changed the time to localtime for the timestamp.
As for the shutdown process I followed this process:
https://raspberrypi.stackexchange.com/questions/89732/run-a-script-at-shutdown-on-raspbian
the first answer that is there. It allows the pi to turn off power with the TPL5111/TPL5110 without ignoring the shutdown. I made a bash script to put pin 17 to high and then followed that answer on stackoverflow using systemd to include it as part of the shutdown process. I believe this helps make sure the camera doesnt mess up when getting a signal to shutdown as I was getting corrupted images before.
cheers,
David
