PWR2006-37 $9 Sub
Goodwill find with "proprietary" VGA audio. No good info found on the interwebs. Guess its time to hack.
Philips thought it would be a great idea to use a VGA connector for 5.1 audio. All of the internet said nothing. Found out pin 1 was the on signal(no switch on the back, it was originally powered on by a signal from a DVD player). Jumping the pin to ground brought the fan on for a second. I had found a "safety" feature. Had to tear open the power supply/amp to find the IC responsible for switching this sucker on. Found a DM311. It will switch on the power if it gets a voltage between 0.5V and 2.5V, 4.5V or more will trigger OL and shut the unit down. Sounds like I found my guy. Jumped a 10K resistor in there and wham bam thank you ma'am I get sound!
rich cornelius wrote 07/22/2019 at 20:20 point
I have the original Philips system and the sound just went on it. I have some guys at work who helped me replace C987 & C988 w identical 470ufd 35V caps. I even replaced the fan, as we could only get the fan to "pulse" and not fully turn on. I plugged the repaired unit back in and still no sound.
I'm interested in any other remedies you may have, including jumping pins 1 & 5 w the 10k resistor. I just need a little more info about this, maybe a pic, etc.
Any help you can offer would be appreciated - in the last month we have been slammed with unforeseen car and house repairs and anything I can do to salvage this system would be great.
Devildogz123456 wrote 04/12/2019 at 04:44 point
got complete setup minus head unit all speaker for 5.00 at flea market, did anyone figure out other speaker inputs
68pishta wrote 01/02/2019 at 00:10 point
jim I got you beat...i got mine for 5.99!
68pishta wrote 01/02/2019 at 00:08 point
ita a 125w peak per channel x 8 so the sub channel s only 125 iirc onto maybe 4ohm. Or 75 into 8ohm.
gabekeway wrote 10/03/2018 at 11:55 point
Any idea what the *actual* output of this amp is? It says 1000W but I'm not so sure that's being honest.
shadowqk wrote 04/21/2018 at 02:36 point
It can be accessed from the "VGA". Found out its not true VGA, wrong grounding.
Pins 1 and 5 can be jumped with a 10K resistor, that should get it to power on and stay on.
Pins 8 and 9 are the subwoofer input. Not sure about the rest.
MAKE SURE YOU ONLY USE LINE LEVEL IN ON THE INPUTS!!!!
I blew a few components on the inside trying to run pre-amped in.
Jimmy D. Burrell wrote 04/21/2018 at 01:36 point
I just bought one of these today, from Goodwill :)  $10.
I've got it torn apart now and looking for the DM311 IC? Which board? PSU or amp? What area?
Or can I just get to it via the VGA conn?
Thanks,
Jim...
