captains log 13
10/20/2017 at 04:03 • 0 commentsIm not dead, im assembling it and testing it with the ocilloscope, to make eveything alot easier and cheaper, ill just use the power source as a 5V which any home charger can handle.
log11
07/16/2017 at 04:25 • 0 comments -
Captains Log #8 or 10
06/25/2017 at 14:55 • 0 commentsdesigning the tape head pcb
Captains Log #9
06/18/2017 at 14:29 • 0 commentsgot the motor in the mail !
Captains Log #8
06/04/2017 at 17:49 • 0 commentsHey everyone, I took a different approach to the cassette tape speed and I found an alternative motor for driving cassette tape. I did simulations to play the cassette tape and the rpm varies between 20-50 rpm. The motor is small which is good becauseit keeps the small form factor.
Captains Log #7
06/02/2017 at 13:46 • 0 commentsSmall change on Distributor to Wuhan P&S
Captains Log #6
06/01/2017 at 16:57 • 0 commentsOk i'm just ordering parts for measuring RPM from EMF. Based off the overall project I think only an arduino pro mini or teensy might be used. Thats good because the cost to build this thing will dramatically decrease.
Captains Log #5
05/31/2017 at 17:05 • 0 commentsI just received 5PC pkg today. I'm just waiting on the giant book of resistors/caps to come in the mail next week. -
Captains Log #4 RPM
05/11/2017 at 06:35 • 0 commentsThe tape has to move at a constant 4.76cm/s rate. Based off the protoype design it didn't include the tachometer to measure the linear speed.
Im going to list 3 ways it may play correctly
- No tachometer, uses a microcomputer for reading the cassette tape and use software to stabilize the changing play speed
- Add a tachometer to read the 4,76cm/rate but the design becomes bulkier with extra parts.
- We discover a new way to play a cassette tape at the right speed somehow.
Captains Log #3
05/10/2017 at 06:09 • 0 commentsThanks to @Morning.Star for recommending a pre-amp for the Casette Tape Head. A Youtube video a google search later
http://piperidis.smartdev.gr/MyWebPage/Contructions/Amplifiers/tapeplayer/tapeplayerEN.htm
