A note about temperature sensors and calibration
08/26/2014 at 12:26 • 0 commentsSo, just to address the niceties of the temperature inputs. I honestly did not have to do much except realize that the numbers were related. This is to say, the numbers for three of the four inputs (Room Air, Outdoor Coil, Outdoor Air) are input/10 = Celsius. The last (Indoor Coil) is input/10 = Fahrenheit. This is how the factory designed it. This helped rapid prototyping quite a bit as I didn't have to do any calibration. The reason for Indoor Coil being different from all of the others is because it runs below 0 Celsius. The Celsius temp probes would not be able to sense anything below (or close to) 0. So, they calibrated the Indoor Coil for Fahrenheit.
This one's a dry read...
08/16/2014 at 17:49 • 0 commentsSo here is the code, and since Hackaday.io doesn't support the code html flag, I will just give it alot of space before I start it and after. I will also eventually share this code on github as well. All of the regular gnu rules still apply. Keep my name on in and if you repost it give me cred. Otherwise enjoy! Oh, and if you have suggestions feel free to drop me a line. I am very approachable like that! ;)
Atwood RV Air Conditioner Controller
This program is designed for an Arduino ProMicro 5V/16MHz from sparkfun.com
software designed, built, and hardware modified by Daniel Roseman 2014 August 13th
#include <EEPROM.h>
#include <avr/wdt.h>
// Defining Variables
int of = 4; //Outdoor Fan Command pin = 4
int heat = 5; //Heat command pin = 5 (PWM)
int comp = 7; //Compressor command pin = 7
int ifa = 8; //Indoor Fan A command pin = 8
int ifb = 9; //Indoor Fan B command pin = 9
int id = A0; //Indoor Coil Analog Input pin = A0
int od = A1; //Outdoor Coil Analog Input pin = A1
int rm = A2; //Room Air Analog Input pin = A2
int oa = A3; //Outdoor Air Analog Input pin = A3
int cool = 14; //12v Cooling command from RV controller
int lfan = 15; //12v Low Fan command from RV controller
int hfan = 16; //12v High Fan command from RV controller
// This setup routine runs once anytime the device starts from scratch
void setup() {
wdt_reset(); //reset watchdog
Serial.begin(300); // open the serial port at 300 bps:
pinMode(of, OUTPUT); // Outside Fan
pinMode(heat, OUTPUT); // Electric Heater
pinMode(comp, OUTPUT); // Compressor
pinMode(ifa, OUTPUT); // Inside Fan Output A
pinMode(ifb, OUTPUT); // Inside Fan Output B
pinMode(id, INPUT); // Indoor Coil Sensor
pinMode(od, INPUT); // Outdoor Coil Sensor
pinMode(rm, INPUT); // Return (Room) Air Sensor
pinMode(oa, INPUT); // Outdoor Air Sensor
pinMode(cool, INPUT); // Cool Call Input
pinMode(lfan, INPUT); // Low Fan Call Input
pinMode(hfan, INPUT); // High Fan Call Input
wdt_enable(WDTO_2S); //Enable watchdog for 2 second delay
if(analogRead(od) > 560){
powerfailSafety();//If outdoor coil temp is above 56c then the outside coil is VERY hot and the compressor "may" have been operating not too long ago. Call powerfailSafety().
if(EEPROM.read(1) == 1){
powerfailSafety2(); //If EEPROM address 1 reads "1" on power up then most likely the power failed while compressor was operating. Call powerfailSafety2().
//Start of Main Loop
void loop() {
if(analogRead(od) > 795){
hightempSafety(); //If outdoor coil goes above 79.5c, call hightempSafety().
if(analogRead(rm) < 150 || analogRead(id) < 200){
freezeSafety(); //If room air temp goes below 15c or indoor coil temp goes below 20F, the call freezeSafety().
delay(1000); //delay 1 second
Serial.print("Indoor Coil = ");
Serial.print(analogRead(id) / 10);
Serial.print("F");
Serial.print("\t");
Serial.print("Outdoor Coil = ");
Serial.print(analogRead(od) / 10);
Serial.print("C");
Serial.print("\t");
Serial.print("Intake Air Temp = ");
Serial.print(analogRead(rm) / 10);
Serial.print("C");
Serial.print("\t");
Serial.print("Outdoor Air Temp = ");
Serial.print(analogRead(oa) / 10);
Serial.print("C");
Serial.print("\t");
Serial.print("Compressor Call = ");
Serial.print(digitalRead(cool));
Serial.print("\t");
Serial.print("Fan Call Low = ");
Serial.print(digitalRead(lfan));
Serial.print("\t");
Serial.print("Fan Call High = ");
Serial.print(digitalRead(hfan));
Serial.print("\t");
Serial.println(" ");
if(digitalRead(cool) == LOW && digitalRead(lfan) == LOW && digitalRead(hfan) == LOW){
digitalWrite(of,LOW);
digitalWrite(comp,LOW);
digitalWrite(ifa,LOW);
digitalWrite(ifb,LOW);
EEPROM.write(1, 0);
compressorLockout();
if(digitalRead(cool) == HIGH && digitalRead(lfan) == HIGH && digitalRead(hfan) == LOW) {
digitalWrite(of,HIGH);
digitalWrite(comp,HIGH);
digitalWrite(ifb,HIGH);
if(EEPROM.read(1) == 0){
EEPROM.write(1, 1);
if(digitalRead(cool) == HIGH && digitalRead(lfan) == LOW && digitalRead(hfan) == HIGH) {
digitalWrite(ifa,HIGH);
EEPROM.write(1, 1);
if(digitalRead(cool) == LOW && digitalRead(lfan) == HIGH && digitalRead(hfan) == LOW) {
EEPROM.write(1, 0);
if(digitalRead(cool) == LOW && digitalRead(lfan) == LOW && digitalRead(hfan) == HIGH){
EEPROM.write(1, 0);
if(digitalRead(cool) == HIGH && digitalRead(lfan) == LOW && digitalRead(hfan) == LOW){
if(digitalRead(cool) == LOW && digitalRead(lfan) == HIGH && digitalRead(hfan) == HIGH){
if(digitalRead(cool) == HIGH && digitalRead(lfan) == HIGH && digitalRead(hfan) == HIGH){
//This routine is called when the Arduino detects that it has been reset due to a power failure via the temperature sensors
void powerfailSafety(){
if(analogRead(id) < 420){
Serial.print("POWER FAIL SAFETY!");
Serial.print(analogRead(id));
return;
//This routine is called when the Arduino detects that it has been reset due to a power failure via the value written in EEPROM
void powerfailSafety2(){
for(int timer = 200; timer > 0; timer--){
Serial.print("Power Fail Safety Timer = ");
Serial.print(timer);
Serial.print("You are seeing this message due to the fact that the A/C thinks the power was removed while in operation.");
return;
void hightempSafety(){
Serial.print("High Temp Safety Timer = ");
Serial.print("You are seeing this message due to the fact that the outdoor coil temp is too high.");
return;
void freezeSafety(){
for(int timer = 720; timer > 0; timer--){
Serial.print("Freeze Safety Timer = ");
Serial.print("You are seeing this message due to the fact that the indoor air temp or indoor coil temp is too low.");
Serial.print("This is usually because the indoor coil has reached a temperature that has caused ice to form on it.");
return;
void compressorLockout(){
Serial.print("Compressor Lockout Timer = ");
Serial.print("You are seeing this message because the compressor has been turned off for less than 10 minutes.");
Serial.print("This is a safety lockout to let the pressure that has built up in front of the compressor drain.");
return;
Nose to the Grindstone...
08/13/2014 at 13:38 • 0 commentsSo, I decided on an arduino platform. For my requirements I needed a couple of things:
First, I needed the ability to measure at least 4 analog values from 0 to 5v.
Second, I needed at least 1 PWM output (for the future electric heater).
Third, I needed at least 3 normal inputs (ie: off, on).
Fourth, I needed one normal output for a heartbeat/status light. And four normal outputs for inside fan high/low, outside fan on, and compressor on.
Fifth, I needed a couple of data lines for future communications.
Sixth, It had to have a watchdog as well as enough memory to hold the many future upgrades planned for it.
Whew! That's a huge list!
Well, after much ado I decided on the Sparkfun ProMicro 5v 16MHz. I could have bought one of those Chinese knock-offs for a lot cheaper, but this thing needed to be rock solid. It fit into the case without too much fuss, and is well designed.
Now to put my nose to the grindstone and get to wiring and coding...
Decisions... decisions...
08/06/2014 at 16:14 • 0 commentsSo, a little primer on the Motorola MCU on this main board. This is an 8-bit 8MHz 5v MCU with 4kb Flash designed by Motorola and built by Freescale Semiconductors. Four of it's input pins are 8-bit A/D converters and has 12 GPIO pins overall. This is a great MCU for professionals and tinkerers alike, as long as you have the proper hardware to program it in the first place.
More important to me in this dive down the rabbit hole, is that it has a security register. Once set, the end user CANNOT read flash contents without wiping it first... Meaning you can reset the MCU to zero but you cannot modify the original code. Since I don't have the equipment to identify whether or not that register had been set, I must assume it had been.
So, I have two options. Buy more equipment that we really can't afford in order to learn then hopefully reprogram an MCU. Or spend a fraction of that investment on a ready-to-program arduino...
And so it begins...
08/06/2014 at 12:43 • 0 commentsOnce we recieved and unwraped the A/C we realized that it required a control box that is sold seperately for more than $150. On closer inspection, the control box connects to the A/C via a four wire connection. 5v and Ground is supplied by the A/C main board and talks via a balanced (two wire) data connection. I didn't try to discover the protocol as our existing onboard control box communicated via dedicated signal lines at 12v. Three to be exact. 12v compressor command, 12v low fan, and 12v high fan. Also I have limited electronics toolset (which does not include an o-scope).
Now I have a problem. Upgrade our entire control system at a huge expense (we are poor BTW), get a different A/C unit at a huge expense (did I forget to mention we are pretty poor...), or I can get to hacking...
Well, the logical choice for me was hack the crap out of it...
And so it begins...
Choosing an A/C...
08/06/2014 at 12:31 • 0 commentsHonestly, I did not realize that I would be starting this endeavor when we first set out to replace one of the two A/C units in our 32' RV. We (me and my wife) thought this would be as easy as changing a window unit... No big deal.
We decided that an Atwood Air Command 15,000 BTU unit was a good choice due to the handling capacity and price (we found this unit online at an RV salvage dealer for $200). Regular unit price hovers around $650 for the unit itself (not including supporting hardware and electronics).
