Tests, decisions, and first try.
08/30/2018 at 06:40 • 0 commentsSo I started by experimenting plenty of solution for detection of the note. First thing first, I tested springs, it worked but had many constraints (especially weight handling and durability).
I then looked at pressure detection, but again, I had problems to tweack it to work for a range between 15 and 120 Kg.
Then I came to the touch board (from a hackaday post BTW). this is a small board embedding an arduino, a mpr121, and a midi sound player. My first octave was born in my head.
I then searched what I can do for the conductive part for detection. i found plenty of very expensive solution, and finally came to this https://fr.aliexpress.com/item/Hot-Sale-100-Silver-Fiber-Fabric-Shielding-Fabric-Silver-Fiber-Conductive-Mesh-Fabric-Anti-static-Mesh/32762274779.html?isOrigTitle=true.
This is a sheet of fabric that is not blocking the light.
I tried to make this work, and created my first octave
This was really a first run, all notes were separated, the design was almost there, but it helped me to understand what I need to do and more important what I need not to.
