Case Top 001.STL3D printable STL file for the top of the case (note: units in mm)Standard Tesselated Geometry - 220.79 kB - 10/19/2017 at 18:56 |
Case Bottom 001.STL3D printable STL file for the bottom of the case (note: units in mm)Standard Tesselated Geometry - 487.48 kB - 10/19/2017 at 18:55 |
Case Top 001.SLDPRTSolidworks file for the top of the casesldprt - 340.02 kB - 10/19/2017 at 18:55 |
Case Bottom 001.SLDPRTSolidworks file for the bottom of the casesldprt - 274.79 kB - 10/19/2017 at 18:55 |
GPS Collar v008.fzzFritzing File for the PCBfzz - 219.19 kB - 10/16/2017 at 03:04 |
GPS Collar PCB V008.zipGerber files for V008 pcb if you want to make it somewhere else.Zip Archive - 188.94 kB - 10/16/2017 at 03:03 |
