HydroponicControl.pdfPreliminary SchematicS1 - Sump low solution S2 - Sump high solution U1 - Solution temperature U2 - Ambient temperature K1 - Sump pump relay K2 - Water valve relay K3 - Nutrient pump relay Adobe Portable Document Format - 20.26 kB - 08/08/2017 at 01:38 |
HydroponicsControl_Version_3.inoChanged from supplementing sump tank from a reserve tank to using a valve controlling normal home water, measuring electrical conductivity and correcting levels with a dosing pump.ino - 13.49 kB - 08/06/2017 at 16:03 |
HydroponicsControl_IUT_Version_1.inoFirst try at ESP8266-12 code. Using push buttons to simulate nutrient solution level and LEDs to indicate pump activation. Basically get some of the logic done as well as a basis to setup the Node-Red code on the Raspberry Pi.ino - 7.88 kB - 06/10/2017 at 00:34 |
